[gdal-dev] debug ogr2ogr on Windows
Joaquim Luis jluis at ualg.pt
Fri Apr 25 12:37:07 PDT 2014
Sorry for bad info than (I had been told that the debugger was not part
of the Express editions)
But you don't need to create project files to run a debugg session. All
it takes is to
File -> Open -> Project/Solution
and load the executable. Yes, the executable. Than go to Project ->
Properties and, if needed change the Working directory, fill the
"Arguments" field with the command line options (but NOT the programs name).
Next go again to File -> Open ->  File and load the source file. From
here on is just to put breaklines and hit F5
Joaquim
> I can't see why you can't debug in express version.
> I used it for many years. That is why I created the makegdal_gen.bat.
> But I don't use express edition now. I use Linux most of the time now.
> > Date: Thu, 24 Apr 2014 22:44:44 +0100
> > From: jluis at ualg.pt
> > To: landa.martin at gmail.com
> > CC: gdal-dev at lists.osgeo.org; david at stripfamily.net
> > Subject: Re: [gdal-dev] debug ogr2ogr on Windows
> > On 24-04-2014 22:20, Martin Landa wrote:
> > > [back to ML]
> > > 2014-04-24 23:18 GMT+02:00 David Strip<david at stripfamily.net>:
> > >> do you have access to visual studio?
> > > sure, as I noted, building using package.cmd script (nmake-based). I
> > > have VS 2010 Express.
> > Others can confirm this, but I'm afraid you wont be able to do an
> IDE debugging with an Express version. It's a petty because VS is
> really good for debugging.
> > gdal-dev mailing list
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140425/797499c6/attachment.html>
