[gdal-dev] accessing netCDF files with /vsicurl fails
Joaquim Luis jluis at ualg.pt
Mon Apr 28 06:34:02 PDT 2014
Thanks for the remainder Etienne, ... but the "Linux only" is a killing
feature for me.
Joaquim
> Even is right - it never worked with the netcdf driver.
> But - it works if you use the vsipreload mechanism
> e.g. http://lists.osgeo.org/pipermail/gdal-dev/2013-May/036359.html
> On Sun, Apr 27, 2014 at 6:03 PM, Joaquim Luis <jluis at ualg.pt
> <mailto:jluis at ualg.pt>> wrote:
>     On 27-04-2014 21:25, Even Rouault wrote:
>         Le dimanche 27 avril 2014 21:50:36, Joaquim Luis a écrit :
>             Hi,
>             This type of command used to work before, but it now
>             errors  (fresh Win7
>             64 GDAL)
>         Joaquim,
>         I doubt it has ever worked with netCDF. The netCDF driver
>         doesn't support the
>         VSI Virtual file system API, since the I/O is done by the
>         netCDF library
>         itself.
>     hmmmmm, I would be willing to swear ... but better not
>     Thanks
>     _______________________________________________
>     gdal-dev mailing list
>     gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140428/7d55d92e/attachment-0001.html>
