[gdal-dev] accessing netCDF files with /vsicurl fails
Even Rouault even.rouault at mines-paris.org
Mon Apr 28 10:55:59 PDT 2014
Le lundi 28 avril 2014 15:34:02, Joaquim Luis a écrit :
> Thanks for the remainder Etienne, ... but the "Linux only" is a killing
> feature for me.
Well, if you really badly need it and are ready to do some development effort,
you could still edit the HDF4 sources and basically add some #ifdef's in a
global include file that they would all include
#define fopen VSIFOpenL
#define fclose VSIFCloseL
#define fread VSIFReadL
etc etc. you got the point.
More points for you if you can do this in a cleaner way by defining a I/O API
in HDF4 lib that would default to the standard C API (fopen, etc...), but
could be overriden by GDAL to plug the VSI Large File API in it, and manage to
make it accepted by HDF4 mainteners.
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
