[gdal-dev] postgis to esri shape slow
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Wed Apr 30 08:41:26 PDT 2014
Mario Jurcevic <mario <at> geosar.ch> writes:
> On 04/30/2014 05:11 PM, Even Rouault wrote:
> > Not that much a big difference... Perhaps you should try to isolate
which layer
> > conversion if particuarly slower with ogr2ogr
> I get big difference:
>   time ogr2ogr -sql 'select
> "soft_gis_serial","Origine","Qualita","Genere",st_curvetoline("Geometria")
> as Geometria from test_export."Copertura_del_suolo__SuperficieCS"'\
>  >  -f "ESRI Shapefile" out.shp PG:'host=localhost dbname=test_soft_gis
> user=test_soft_gis password=passwd'
> Warning 6: Normalized/laundered field name: 'soft_gis_serial' to
> 'soft_gis_s'
> real	0m2.359s
> user	0m0.040s
> sys	0m0.004s
> With debug on there there is many notice of ogr analyzing geom tables.
> Maybe that is, your dump miss has not the whole db.
Could you make one more test by creating a table that is already cleared
from curves inside PostGIS as
create table curves_as_lines as
select [your sql];
This test should reveal if st_curvetoline is the bottleneck.
-Jukka Rahkonen-
