[gdal-dev] python scripts - create layer problem
Martin Landa landa.martin at gmail.com
Fri Aug 1 04:31:56 PDT 2014
Hi Even,
2014-07-11 11:33 GMT+02:00 Even Rouault <even.rouault at mines-paris.org>:
> If you see the CREATE TABLE in the debug log, and it is not created, then it is
> really weird. Perhaps check the potential surrounding BEGIN/COMMIT/ROLLBACK just
> in case. Might it not be an issue with your PostgreSQL instance ?
I tried your suggestions and then I checked again my scripts. The
problem was not in GDAL, but in my scripts. Sorry for the noise and
thanks for your help!
Martin
Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
