[gdal-dev] GSoC 2014 Weekly Report 11 : GDAL PostGIS Raster driver
Varun Saraf varunsaraf14 at gmail.com
Mon Aug 4 13:53:03 PDT 2014
Hello,
Commenting poDriver->pfnCreateCopy doesn't seem to work. It is still
calling the CreateCopy() method. I will try doing the testing with a script
and get back to you.
Regards,
Varun Saraf
On Tue, Aug 5, 2014 at 2:12 AM, Even Rouault <even.rouault at mines-paris.org>
wrote:
> Le lundi 04 août 2014 22:38:20, Varun Saraf a écrit :
> > Hello,
> > Thank you for this information. I will explicitly call Create() using a
> > script. Is the IWriteBlock method to be tested in a similar manner? Note
> > that pData buffer is passed to this method as an argument, which I will
> > have to generate and pass to it. Any suggestions how I should generate
> this
> > pData buffer?
> Well, any data might do.
> But based on my previous note regarding the generic GDAL core CreateCopy()
> implementation, another possibility for your testing is to temporarily
> comment
> poDriver->pfnCreateCopy = .... and use gdal_translate.
> > Regards,
> > Varun Saraf
> > On Tue, Aug 5, 2014 at 1:44 AM, Even Rouault <
> > wrote:
> > > Le lundi 04 août 2014 21:38:36, Varun Saraf a écrit :
> > > > Hello,
> > > > Yes, the code on the github repository is the latest state. I was
> > > > trying the following input queries :
> > > > (1) Assuming that my Create() will be called.
> > > > gdal_translate --debug ON -of PostGISRaster ~/GSoC/ap_clip5x5.tif
> > > >  PG:"host=localhost port=5432 user=postgres password=postgres
> > > > dbname=test123 table=newtable"
> > > > (2) When that did not work, I tried the following (suggested by my
> > > mentor,
> > > > Jorge Arevalo) which didn't work either.
> > > > gdal_translate --debug ON -of PostGISRaster -outsize 50% 50%
> > > > ~/GSoC/ap_clip5x5.tif  PG:"host=localhost port=5432 user=postgres
> > > > password=postgres dbname=test123 table=newtable"
> > > gdal_translate will never call Create(), but only CreateCopy().
> > > You might want to call Create() directly with a Python script for
> > > example, or
> > > a sample C/C++ code. gdalwarp will call Create() too, but gdalwarp can
> > > potentially rewrite existing tiles, which can complicate your initial
> > > coding.
> > > > QuiteDelete() method is called in both cases and the following error
> > > > messages are shown
> > > > ERROR 1: Couldn't drop the table public.newtable: ERROR:  table
> > > "newtable"
> > > > does not exist
> > > > ERROR 6: PostGISRasterDataset::CreateCopy() only works on source
> > > > datasets that are PostGISRaster
> > > Yes, as the message implies, the current CreateCopy() implementation
> only
> > > works when the source dataset is a postgisraster dataset itself.
> > > As far as the error message "Couldn't drop ...",
> > > PostGISRasterDataset::Delete() should probably be more silent in case
> the
> > > dataset doesn't exist.
> > > Note that once you have a full feature Create() implementation (with
> > > working
> > > IWriteBlock() of course), CreateCopy() is no longer strictly needed,
> > > since there is generic implementation in GDAL core that will emulate
> > > CreateCopy() with Create() + IWriteBlock()
> > > > I even tried calling the Create() method directly from CreateCopy(),
> > > since
> > > > that is being called, but again the same error message is being
> > > > printed.
> > > > Regards,
> > > > Varun Saraf
> > > > On Mon, Aug 4, 2014 at 11:33 PM, Even Rouault
> > > > wrote:
> > > > > Le lundi 04 août 2014 14:39:52, Varun Saraf a écrit :
> > > > > >  Hi,
> > > > > > Below is my eleventh weekly report.
> > > > > > *What did I do this week?*
> > > > > >    - There are some issues with the calling of different methods.
> > > > > >    My
> > > > > method
> > > > > >    PostGISRasterDataset::Create() is not being called. Tried to
> > > resolve
> > > > > > that.
> > > > > Varun,
> > > > > If the code at
> https://github.com/varunsaraf/postgis_raster/blob/master/postgisrasterdat
> > > > > aset.cpp is the latest state, I don't see any reason why your
> > > > > Create() method wouldn't
> > > > > be called. Do you try to trigger it directly by calling Create()
> > > > > explicetely
> > > > > or through other more high level operations ?
> > > > > Even
> > > > > > - Fixed some small bugs and removed unnecessary variables that
> were
> > > > > > being used.
> > > > > > *What do I plan on doing next week?*
> > > > > >    - Continue with testing and bug fixing.
> > > > > > *Am I blocked on anything?*
> > > > > >    - No.
> > > > > > Link to weekly report :
> > > > > > https://github.com/varunsaraf/postgis_raster/wiki/Report-11
> > > > > > Link to code repository :
> > > > > > More details at :
> > > http://trac.osgeo.org/gdal/wiki/PostGIS_raster_driver
> > > > > > Regards,
> > > > > > Varun Saraf
> > > > > > Lab for Spatial Informatics
> > > > > > IIIT Hyderabad, India
> > > > > Geospatial professional services
> > > > > http://even.rouault.free.fr/services.html
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140805/0179ca2d/attachment.html>
