[gdal-dev] NITF read slow in python
Even Rouault even.rouault at spatialys.com
Wed Aug 6 11:24:43 PDT 2014
Le mercredi 06 août 2014 20:16:57, John_Lunzer a écrit :
> They are listed as C8, which means JPEG2000 compression.
That must be it. JPEG2000 decompression takes some time, and that can be more
or less slow depending on the underlying driver used. Do you have JP2KAK,
JP2ECW, JP2OPENJPEG, JP2MrSID or JPEG2000 drivers enabled ? (if you have
several, they are used in the mentionned order)
> http://osgeo-org.1560.x6.nabble.com/NITF-read-slow-in-python-tp5155297p515
> 5304.html Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
