[gdal-dev] GSoC 2014 Weekly Report 11 : GDAL PostGIS Raster driver
Varun Saraf varunsaraf14 at gmail.com
Thu Aug 7 13:26:07 PDT 2014
Hello,
Thanks. I will use that.
When the PostGISRasterDataset::SetProjection method returns, a segmentation
fault is being shown. The methods I have made changes to IWriteBlock,
IRasterIO are not being called. What is the following flow of methods that
are called? What could be the issue?
Regards,
Varun Saraf
On Fri, Aug 8, 2014 at 1:22 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Le jeudi 07 août 2014 21:26:31, Varun Saraf a écrit :
> http://trac.osgeo.org/gdal/browser/trunk/gdal/frmts/postgisraster/postgisra
> > sterdataset.cpp#L3024
> I suggested you to look at OGRPGDataSource::FetchSRSId() (
> http://trac.osgeo.org/gdal/browser/trunk/gdal/ogr/ogrsf_frmts/pg/ogrpgdatasource.cpp
> . It contains everything you need. You could/should actually reuse it
> directly
> in PostgisRaster.
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140808/6d59cb96/attachment.html>
