[gdal-dev] GDAL, ESRI Shapefiles and nested polygons
Even Rouault even.rouault at spatialys.com
Thu Aug 7 13:26:51 PDT 2014
Le jeudi 07 août 2014 22:20:34, Graeme Wilkie a écrit :
> Hi,
> I'm trying to use GDAL to read ESRI shapefiles. I've got it working for
> points, lines, polygons, polylines and multipoint but I'm having problems
> with polygons that contain polygons in the same feature.
> The following is a cut down code sample of the code I'm using. The problem
> I have is that I can read the number of polygons in the feature (i.e. 3
> polygons, nested) using OGR_G_GetGemoetryCount. When I use
> OGR_R_GetGeometryRef to get the handle/pointer for each of the polygons in
> turn I get what appears to be a valid handle but when I use it to get the
> number of points/vertices in the polygon it always returns 0.
Graeme,
You didn't display the WKT that corresponds to the geometry, so I will just
make the guess that the geometries returned is a multipolygon and not a
polygon.
So you might need one more level of OGR_G_GetGeometryCount and
OGR_G_GetGeometryRef to go to the ring level.
Best regards,
Even
http://www.spatialys.com
