[gdal-dev] OGR: memory leak in OCI driver
Ivan Lucena lucena_ivan at hotmail.com
Fri Aug 8 08:08:06 PDT 2014
Your patch was committed to trunk, backported to 1.11 and 1.10. Ticked #5590 close.
Please verify.
Regards,
Ivan
To: gdal-dev at lists.osgeo.org
Date: Fri, 1 Aug 2014 14:49:35 +0000
Subject: Re: [gdal-dev] OGR: memory leak in OCI driver
Hi list,
                We tested the suggestion of Ivan and it’s better.
                Fortunately, my problem to create ticket was solved
The ticket is  http://trac.osgeo.org/gdal/ticket/5599 with a patch file.
Best regards
Nicolas
De : Ivan Lucena [mailto:lucena_ivan at hotmail.com]
Envoyé : mardi 6 mai 2014 17:48
À : SIMON Nicolas; gdal-dev at lists.osgeo.org
Cc : SANDRI Christophe; NGUYEN Thi Xuan Truc
Objet : RE: [gdal-dev] OGR: memory leak in OCI driver
Hi Nicolas,
I received that report a month ago:
"we have found the OGROCISession is never released, causing a large memory leak whenever a connection is closed.
As workaround, we added in OGROCISession::~OGROCISession()
    if( hEnv )
           OCIHandleFree((dvoid *) hEnv, (ub4) OCI_HTYPE_ENV);"
But they also mention some other memory leaks without an specific location on the code.
Can you try to see if that fix the problem?
Thanks,
Ivan
nicolas.simon at spw.wallonie.be
Date: Tue, 6 May 2014 15:32:09 +0000
CC: christophe.sandri at spw.wallonie.be;
xuan.nguyen at spw.wallonie.be
Subject: [gdal-dev] OGR: memory leak in OCI driver
Dear developers,
                I suspect that there is a memory leak in OCI driver for OGR
                My simplified test case is :
// point A
OGRRegisterAll();
// point B
pDS = OGRSFDriverRegistrar::Open("OCI:USER/PWD at INSTANCE:TABLE", true);
if(pDS)
          OGRDataSource::DestroyDataSource(pDS);
          pDS = NULL;
     else
          fprintf(fOut,"Erreur Open\n");
     // point C
OGRCleanupAll();
// point D
It appears that I lose memory between points B and C, and between point A and D
                B = A + 4 MB
                C = A + 20 MB ( 16 MB lost)
               D = A +19 MB ( 3 more MB lost)
Test was done with GDAL 1.9 under windows (with Oracle 11g)
Can some one have an idea to find and fix this ?
Thank you
By the way,  I received « TICKET_CREATE privileges are required to perform this operation » when I tried to make a ticket (UID nicsim)
Nicolas
_______________________________________________ gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140808/72b4d51a/attachment-0001.html>
