[gdal-dev] How to get string representation from OGRStyleMgrH
Nik Sands nixanz at nixanz.com
Sun Aug 10 03:36:02 PDT 2014
Is there a C API equivalent?  Or some other way of doing this without C++?
I'm using C rather than C++.
On 10 Aug 2014, at 7:30 pm, Even Rouault <even.rouault at spatialys.com> wrote:
> Le dimanche 10 août 2014 08:05:48, Nik Sands a écrit :
>> Hi devs,
>> I've been working with styles using 'OGRStyleMgrH'.  However, I cannot
>> figure out how to get a string directly from an OGRStyleMgrH.  I'd like to
>> be able to get the string representation of the style in the same format
>> as can be used to initialise the OGRStyleMgrH in OGR_SM_InitStyleString().
> Nik,
> OGRStyleMgr::GetStyleString(NULL) should do :
> * \brief Get the style string from the style manager.
> * @param poFeature feature object from which to read the style or NULL to
> *                  get the style string stored in the manager.
> * @return the style string stored in the feature or the style string stored
> *          in the style manager if poFeature is NULL
> * NOTE: this method will call OGRStyleMgr::InitFromFeature() if poFeature is
> *       not NULL and replace the style string stored in the style manager
> Even
>> How can I do this?
>> Cheers,
>> Nik.
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Spatialys - Geospatial professional services
> http://www.spatialys.com
