[gdal-dev] GPKG application_id
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Tue Aug 12 07:01:38 PDT 2014
Even Rouault <even.rouault <at> spatialys.com> writes:
> Hi Paul,
> > Others are less likely. I’ve learned that GeoServer is emitted GPKG files
> > without the application_id set.
> Hum, do they plan fixing that at some point ? Couldn't they do the same trick
> we do (direct editing) ?
According to Geotools jira http://jira.codehaus.org/browse/GEOT-4816 this
issue is fixed two days ago.
-Jukka Rahkonen-
