[gdal-dev] GDAL - GDB issue
Even Rouault even.rouault at spatialys.com
Sat Aug 16 00:59:06 PDT 2014
Selon Scott Rowles <scott_rowles at hotmail.com>:
> Even,
> I found a new error when parsing a very large file.  Seems to be something in
> one of the source files:  line 1064
> Can you give me an idea what this might be?
Scott,
This is perhaps a defect in the OpenFileGDB driver. I would need access to the
data to examine what is going on. Could you create a ticket in Trac (see the top
of http://trac.osgeo.org/gdal/ on how to do that) and provide in it a link to
the data or attach the data itself as a zip if it is small ? And specify which
filename you provided to Open().
Even
> scott
> > Date: Fri, 15 Aug 2014 22:52:32 +0200
> > From: even.rouault at spatialys.com
> > To: scott_rowles at hotmail.com
> > CC: even.rouault at spatialys.com; gdal-dev at lists.osgeo.org
> > Subject: RE: [gdal-dev] GDAL - GDB issue
> > > OK.  It threw some errors about a missing .csv file which I didn't have
> > > installed in the solution.  Working on adding that now.  Why doesn't
> ogr.Open
> > > return a more clear error?
> > Please keep the list CC'ed. And when you mention errors that are thrown,
> you
> > should copy them verbatim to avoid crystal glass guessing ;-)
> > Well, I suppose it must have been about the gcs.csv/pcs.csv files that
> contain
> > the EPSG projection database. Try to locate where they are installed in
> your
> > distribution and define the GDAL_DATA environment variable to point to the
> > directory where they are located.
> > > > Date: Thu, 14 Aug 2014 19:45:09 +0200
> > > > > Even,
> > > > > No.  Where do I find/download the ogrInfo utility.  I will try that!
> > > > It should be included in every binary distribution of gdal (e.g.
> > > > http://gisinternals.com/sdk/). Or if you compile it from source. It is
> one
> > > of
> > > > the many utilities coming with the GDAL library.
> > > > > scott
> > > > > > Date: Thu, 14 Aug 2014 19:25:40 +0200
> > > > > > CC: gdal-dev at lists.osgeo.org
> > > > > > Subject: Re: [gdal-dev] GDAL - GDB issue
> > > > > > > Hi,
> > > > > > > I have an implementation with C# using GDAL 1.11 binaries.
> According
> > > to
> > > > > the
> > > > > > > documentation it should process GDB files either as a .zip file,
> as a
> > > > > .gdb
> > > > > > > folder or as a .gdbtalbe individually.
> > > > > > > I have tried all 3 of them and each one gives me an ogc.Open,
> cannot
> > > open
> > > > > > > this file type error.
> > > > > > > Is there a switch I need to set or anything I need to do in the
> GDAL
> > > > > > > configuration to enable GDB conversion?
> > > > > > Well, it should work. Did you try with the ogrinfo utility to see
> if
> > > the
> > > > > dataset
> > > > > > is recognized ?
> > > > > > Even
> > > > > > Spatialys - Geospatial professional services
> > > > > > http://www.spatialys.com
