[gdal-dev] libkml support issues
Jeff McKenna jmckenna at gatewaygeomatics.com
Mon Aug 18 03:53:23 PDT 2014
For MS4W builds I follow the wiki page for LibKML at:
https://trac.osgeo.org/gdal/wiki/LibKML
As it states there, you should get the source through github at:
https://github.com/google/libkml
In my builds, I use expat-2.1.0, and (following that wiki page) I change
the 'third_party' path to my own expat lib file.
PS. please don't be afraid to update that wiki page with any helpful
notes, as you travel down this path.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2014-08-17 9:46 PM, Robert Zermeno wrote:
> GDAL folks,
> I am trying to support kml support via libkml library in MSVC2008
> environment (Windows 32-bit environment on Windows 7).  I have
> downloaded the repository version as stated in the gdal webpage, built a
> static library of each required libkml component, and updated nmake.opt
> to build the libkml support.
> Everything worked fine and in my shell program I have a simple API call
> to verify GDAL can read kml products:
> 'GDALOpenEx(kmlFile.c_str(), GDAL_OF_VECTOR, NULL, NULL, NULL);'
> Now, I keep getting a Access violation reading error in
> "xmlchar_to_utf8()" in expat_handler.h file in kmlbase.
> Has anyone experienced this issue lately?  Which version of expat should
> I link against?
> In the nmake.opt do I uncomment the component to link Expat for libkml
> support or is that only used for internal KML driver?
> I am trying to figure out if I have a libkml issue?  I downloaded the
> repository at "http://libkml.googlecode.com/svn/trunk/"
> Is that the right location to get version 1.3?
> Thanks in advance,
> Robert
