[gdal-dev] Build GDAL from scratch on CentOS 6.5 (Jake Brinkmann)
Jose Gomez-Dans jgomezdans at gmail.com
Mon Aug 18 09:59:50 PDT 2014
Hello,
I have produced a GDAL (1.11.0) binary for Anaconda with HDF4, HDF5 and
NetCDF for X86_64. It should just work by installing standard anaconda and
issuing the following command:
conda install -c https://conda.binstar.org/jgomezdans gdal=1.11.0
The list of supported raster formats is available here:
https://gist.github.com/jgomezdans/11c1bb9ce266495e6544, but in reality, I
need it for working with MODIS data, so only tested MODIS, HDF5 and netcdf.
Hope it's of use to other people!
Jose
On 18 August 2014 14:54, Jake Brinkmann <jakebrinkmann at gmail.com> wrote:
> Hey Daniel,
> Much appreciated! I think building my own on a VM might be the next thing
> I try.
> I attempted to use jevans version, with a fresh install of Anaconda, but
> to no avail.
> The code here: https://gist.github.com/jake-brinkmann/fb4bd3f4625b209978d0
> still didn't work.
> I'll look through the examples to attempt again after building my own
> package.
> Thank you!
> Jake
> On Sat, Aug 16, 2014 at 4:34 AM, Daniel Clewley <daniel.clewley at gmail.com>
> wrote:
>> Hi Jake,
>> As you mentioned Anaconda Python, one options is to install a different
>> GDAL build from binstar someone has built with HDF4 support or build
>> yourself using the conda build system on a virtual machine you have root
>> access to and then install these binaries through conda.
>> A quick search of binstar.org showed the following user with GDAL built
>> against HDF4:
>> https://binstar.org/jevans
>> You should be able to install this version of GDAL through conda using:
>> conda install -c https://conda.binstar.org/jevans gdal
>> Note: I haven't tested this.
>> Building your own packages is a bit more involved - basically you create
>> a recipe and then build it using:
>> conda build recipe-folder
>> There is a github repository with lots of examples here:
>> https://github.com/conda/conda-recipes/
>> We've built GDAL and other software through conda for Linux and OS X
>> under virtual machines and installed on different machines (without root
>> access) and it's worked pretty well.
>> Hope this helps and the discussion of conda isn't too off topic.
>> Thanks,
>> Dan
>> On 15 Aug 2014 23:11, Even Rouault <even.rouault at spatialys.com> wrote:
>> > Jake,
>> > well if you don't have the basic build dependencies, this might get
>> > complicated... Nothing impossible, but might take time indeed.
>> > Well one possibility is to access a CentOS where you have a root access
>> (e.g. a
>> > VM that you install), build on it, and then copy the resulting binaries.
>> > Even
>> >> Hey Even,
>> >> Thank you for outlining this. The trouble I have is that, without root
>> >> access, `make install` is a never-ending list of missing libraries, or
>> >> compilation errors...
>> >> Do you know of a way to resolve the missing libraries without root
>> access
>> >> (and without wasting the next 48hours untaring, compiling, and
>> installing)?
>> >> Just as an example, I cant even compile the HDF4 source with
>> `./configure
>> >> --prefix=/have/write/access` because of something with Fortran and
>> g77... I
>> >> disable fortran as `./configure --prefix=/have/write/access
>> >> --enable-fortran=NO` but then it fails due to missing yacc utility....
>> This
>> >> continues until I get so lost as to what library I'm installing for
>> what
>> >> package, that it just seems there must be an easier way...
>> >> If you have any thoughts, please, let me know.
>> >> Thank you for reaching out.
>> >> Jake
>> >> On Fri, Aug 15, 2014 at 4:45 PM, Even Rouault <
>> >> wrote:
>> >>> Selon Jake Brinkmann <jakebrinkmann at gmail.com>:
>> >>>> Hello all geospatial-web-wizards,
>> >>>> I am struggling pretty hard building the GDAL libraries and all the
>> >>>> countless dependencies from source in CentOS6.5. I do not have root
>> >>> access
>> >>>> on my machine, but I need the GDAL (as well as HDF, GeoTiff, GEOS,
>> etc.)
>> >>>> libraries for performing image processing using the Terra/Aqua MODIS
>> >>>> satellite remote sensing data.
>> >>>> Does anyone out there have experience building GDAL along with HDF
>> and
>> >>>> Python bindings, but without, and I emphasize here: *without* root
>> >>> access?
>> >>>> Alternatively, if possible, I would be willing to install a binary,
>> but
>> >>>> remember: I do not have root access (so I'm not sure this would
>> work...)
>> >>>> and lack experience with *.rpm files
>> >>>> Let me know, please, if anyone has any ideas at all.
>> >>>> I am really wishing the Anaconda Python distribution would come with
>> GDAL
>> >>>> supporting HDF4, but it currently does not...
>> >>>> Thanks for reading, and any help you can provide,
>> >>> Jake,
>> >>> It is always possible to build without root access.
>> >>> The scheme is :
>> >>> 1) Download HDF4 sources, untar, cd to the source directory
>> >>> 2) ./configure --prefix=/somewhere/where/you/have/write/access
>> >>> 3) make install
>> >>> 4) Download GDAL sources, untar, cd to the source directory
>> >>> 5) ./configure --prefix=/somewhere/where/you/have/write/access
>> >>> --with-hdf4=/somewhere/where/you/have/write/access
>> >>> 6) make install
>> >>> 7) cd swig/python
>> >>> 8) python setup.py build
>> >>> 9) export PYTHONPATH=$PWD/build/lib.linuxXXXXXXXX (to be adapted
>> depending
>> >>> on
>> >>> your architecture and Python version)
>> >>> 10) export PATH=/somewhere/where/you/have/write/access/bin:$PATH
>> >>> 11) export LD_LIBRARY_PATH=/somewhere/where/you/have/write/access/lib
>> >>> You should be done.
>> >>> Even
>> >>> Spatialys - Geospatial professional services
>> >>> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140818/2a81c6e1/attachment.html>
