[gdal-dev] Planning for 1.11.1 release ?
Flippmoke flippmoke at gmail.com
Tue Aug 19 07:07:36 PDT 2014
I wouldn't mind learning some of it, but would rather not being in charge of it.
Thanks,
Blake Thompson
> On Aug 19, 2014, at 8:53 AM, Even Rouault <even.rouault at spatialys.com> wrote:
> Hi,
> The 1.11 branch has accumulated 57 fixes [1] since the 1.11.0 release (perhaps a
> bit more if some of them went to the 1.10 branch as well), so it might be good
> to think producing a maintenance release with them.
> What do you think of end of September to produce an RC (let's say September
> 24th) ?
> If there are outstanding regressions that should be fixed for 1.11.1, raise
> tickets and cook up your patches !
> There are 7 tickets currently opened against 1.11.1 milestone ([2]). GDAL
> committers, please have a look at them and update milestone if needed.
> Anyone volunteering to do the release process ? If nobody else wants, I will.
> Best regards,
> Even
> [1]
> http://trac.osgeo.org/gdal/query?status=closed&group=resolution&order=priority&milestone=1.11.1&resolution=fixed
> [2]
> http://trac.osgeo.org/gdal/query?status=assigned&status=new&status=reopened&group=resolution&order=priority&col=id&col=summary&col=owner&col=type&col=priority&col=component&col=version&milestone=1.11.1
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
