[gdal-dev] Projection issues with PAMAP LiDAR
Even Rouault even.rouault at spatialys.com
Tue Aug 19 13:59:27 PDT 2014
Selon "Wood, Alexander" <awood at agi.com>:
> I recently ran into a projection problem with the PA LiDAR dataset and saw
> that Ticket #4954 documents the issue.  Even had mentioned (in the forum
> thread linked in that Trac ticket) that he has a patch for this issue.
Did I ? I can remember this issue is regularly raised but AFAIK nobody has
produced a patch yet.
> I was
> just wondering if there were plans to include this in the 1.11.1 release.  It
> is currently targeted to 1.11.0.
> Thanks,
> Alex
http://www.spatialys.com
