[gdal-dev] GDAL translate 16 bit to 8 bit
Even Rouault even.rouault at spatialys.com
Thu Aug 21 11:33:14 PDT 2014
Le jeudi 21 août 2014 08:57:32, Hanlie Pretorius a écrit :
> Hi,
> I'm working with a 16 bit SPOT 6 image that I want to convert from 16
> bit pixel depth to 8 bit pixel depth. I say 16 bit, but if I load the
> file into Envi, it reports that uses only 12 bits. However gdalinfo
> reports 16 bit (see below).
> I've manage to do so on the multispectral image, but the result is
> poor colour wise.
> So I split the image into its four bands that is, I now have one image per
> band.
> When I now try to convert to 8 bit, I get a message that says:
> "Warning 742327101_R1C1_band1_8bit.TIF not created".
Are you quoting the exact message ? I can't find any trace of it in the
relevant parts of the source code. Did you check that you have write
permissions in the directory where you launch the command ?
Anyway for what you want to do you likely need to explore the -scale option of
gdal_translate. But that's unrelated to the error
> The command I'm using is:
> gdal_translate -ot Byte -of GTiff "D:/SPOT
> 6/EightBit/IMG_SPOT6_MS_201304290812030_ORT_742327101_R1C1_band1.TIF"
> gdalinfo for the original MS image gives the following result:
> Driver: GTiff/GeoTIFF
> Files: D:/SPOT
> 6/SANSA_SouthAfr_246_SO13012989_43_DS_SPOT6_201304290812030_FR1_FR1_SE1_SE
> 1_E021S32_03414/PROD_SPOT6_001/VOL_SPOT6_001_A/IMG_SPOT6_MS_001_A/IMG_SPOT6
> _MS_201304290812030_ORT_742327101_R1C1.TIF D:/SPOT
> _MS_201304290812030_ORT_742327101_R1C1.tif.ovr D:/SPOT
> _MS_201304290812030_ORT_742327101_R1C1.TFW D:/SPOT
> _MS_201304290812030_ORT_742327101_R1C1.TIF.aux.xml Size is 7680, 7680
> Coordinate System is:
> PROJCS["WGS 84 / UTM zone 34S",
>     GEOGCS["WGS 84",
>         DATUM["WGS_1984",
>             SPHEROID["WGS 84",6378137,298.257223563,
>                 AUTHORITY["EPSG","7030"]],
>             AUTHORITY["EPSG","6326"]],
>         PRIMEM["Greenwich",0],
>         UNIT["degree",0.0174532925199433],
>         AUTHORITY["EPSG","4326"]],
>     PROJECTION["Transverse_Mercator"],
>     PARAMETER["latitude_of_origin",0],
>     PARAMETER["central_meridian",21],
>     PARAMETER["scale_factor",0.9996],
>     PARAMETER["false_easting",500000],
>     PARAMETER["false_northing",10000000],
>     UNIT["metre",1,
>         AUTHORITY["EPSG","9001"]],
>     AUTHORITY["EPSG","32734"]]
> Origin = (426894.000000000000000,6421830.000000000000000)
> Pixel Size = (6.000000000000000,-6.000000000000000)
> Metadata:
>   AREA_OR_POINT=Area
>   TIFFTAG_DATETIME=2013:12:05 14:23:06
>   TIFFTAG_IMAGEDESCRIPTION=B2, B1, B0, B3
>   TIFFTAG_XRESOLUTION=6
>   TIFFTAG_YRESOLUTION=6
> Image Structure Metadata:
>   INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left  (  426894.000, 6421830.000) ( 20d13'23.42"E, 32d20'16.91"S)
> Lower Left  (  426894.000, 6375750.000) ( 20d13'10.50"E, 32d45'13.25"S)
> Upper Right (  472974.000, 6421830.000) ( 20d42'46.12"E, 32d20'24.35"S)
> Lower Right (  472974.000, 6375750.000) ( 20d42'41.34"E, 32d45'20.81"S)
> Center      (  449934.000, 6398790.000) ( 20d28' 0.35"E, 32d32'49.70"S)
> Band 1 Block=7680x128 Type=UInt16, ColorInterp=Red
>   Min=0.000 Max=2768.000
>   Minimum=0.000, Maximum=2768.000, Mean=254.357, StdDev=82.827
>   Overviews: 3840x3840, 1920x1920, 960x960, 480x480, 240x240
>   Metadata:
> STATISTICS_COVARIANCES=6860.33555334015,5408.39177012214,3932.59000707709,
> 8359.55872888383 STATISTICS_MAXIMUM=2768
>     STATISTICS_MEAN=254.35743888007
>     STATISTICS_MINIMUM=0
>     STATISTICS_SKIPFACTORX=1
>     STATISTICS_SKIPFACTORY=1
>     STATISTICS_STDDEV=82.827142612432
> Band 2 Block=7680x128 Type=UInt16, ColorInterp=Green
>   Min=0.000 Max=1928.000
>   Minimum=0.000, Maximum=1928.000, Mean=272.449, StdDev=67.362
>   Metadata:
> STATISTICS_COVARIANCES=5408.39177012214,4537.57701249689,3512.4873688442,6
> 910.89114933438 STATISTICS_MAXIMUM=1928
>     STATISTICS_MEAN=272.44932240804
>     STATISTICS_STDDEV=67.361539564479
> Band 3 Block=7680x128 Type=UInt16, ColorInterp=Blue
>   Min=0.000 Max=2264.000
>   Minimum=0.000, Maximum=2264.000, Mean=291.925, StdDev=54.875
>   Metadata:
> STATISTICS_COVARIANCES=3932.59000707709,3512.4873688442,3011.23474438976,5
> 111.02811591707 STATISTICS_MAXIMUM=2264
>     STATISTICS_MEAN=291.92457129584
>     STATISTICS_STDDEV=54.874718626976
> Band 4 Block=7680x128 Type=UInt16, ColorInterp=Undefined
>   Min=0.000 Max=2699.000
>   Minimum=0.000, Maximum=2699.000, Mean=374.146, StdDev=115.219
>   Metadata:
> STATISTICS_COVARIANCES=8359.55872888383,6910.89114933438,5111.02811591707,
> 13275.4755734648 STATISTICS_MAXIMUM=2699
>     STATISTICS_MEAN=374.14637317234
>     STATISTICS_STDDEV=115.21925001259
> gdalinfo for band 1 of the image that I'm trying to use for the
> conversion, gives the following results:
> Files: D:/SPOT
>     GEOGCS["WGS 84",
>         DATUM["WGS_1984",
>     UNIT["metre",1,
> Metadata:
>   AREA_OR_POINT=Area
>   INTERLEAVE=BAND
> Corner Coordinates:
>   Metadata:
>   Metadata:
>   Metadata:
>   Metadata:
> I'm using QGIS 2.2.0 on Windows 8 as a front end to GDAL.
> Can anyone perhaps see why the error is occurring or suggest an
> alternative workflow?
> Thanks
> Hanlie
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
