[gdal-dev] gdaldem color-relief does not produce any result
Cleo Drakos cleo21drakos at gmail.com
Fri Aug 22 07:48:29 PDT 2014
I have a geotiff file with class values (0, 1,  2, 3, and 4).
I want to show each class as different rgb color.
So, I created the text file (color_relief.txt) which contans the following:
0 55 78 94
1 98 23 64
2 112 35 99
3 34 67 72
4 78 250 60
Then I run the following code using python:
import subprocess
in_file =  'single_band.tif'
text_file = 'color_relief.txt'
gdaldem = 'C:\\Python27\\Lib\\site-packages\\osgeo\\gdaldem.exe'
out_file =  'result.tif'
subprocess.call([gdaldem
,'color-relif',in_file,text_file,out_file,'-exact_color_entry','-b','1'],shell=True)
in_file, out_file = None, None
Unfortunately, no result file is obtained.
What is wrong with my code?
cleo
On Fri, Aug 22, 2014 at 6:37 PM, Cleo Drakos <cleo21drakos at gmail.com> wrote:
> I have a single band geotiff file with discrete data in bytes.
> The unique data values are 0, 1,  2, 3, and 4.
> I want to intrepret each unique value as rgb color.
> following:
> 0 55 78 94
> 1 98 23 64
> 2 112 35 99
> 3 34 67 72
> 4 78 250 60
> import subprocess
> cleo
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140822/5d217c8b/attachment.html>
