[gdal-dev] RFC 47 and Threading
Even Rouault even.rouault at spatialys.com
Fri Aug 22 11:10:21 PDT 2014
> > Quick question - presumably for VRT datasets any source images currently
> > share the global cache and are treated from this proposals' POV as their
> > own "datasets"? As well as the VRT being a separate dataset? If so, seems
> > like this could be quite a major win for users with VRTs for tiled
> > images?
> The GDALRasterBlockManger if done per dataset is a member of the base
> GDALDataset Object, so all inherited classes will have it as well. So yes,
> I believe that should be the case that each seperate dataset in the VRT
> would have its own cache. All of this is assuming you set the global config
> option to use a per dataset cache.
This might be a problem in practice since the amount of cache might grow
quickly. By default a VRT will open simultaneously up to
GDAL_MAX_DATASET_POOL_SIZE (whose default is 100, but can be changed at
runtime with the config option) source datasets.
If you do a gdal_translate of the VRT (and that it has more than 100 sources)
then you will need 100 * GDAL_CACHEMAX bytes for the cache.
Of course once you are aware of that you can play with both configuration
options to find the best settings.
> > While it's a lot of code change, it's mostly simple/repeated changes.
> > > Solution 2 (RW Mutex in GDALRasterBlock)
> > > Cons:
> > > It means that writing a driver is not as trivial as before and care
> > > must
> > be taken in how locking is done within the driver in order to prevent
> > deadlocks and maintain thread safety.
> > I'm wary about making drivers more complex, there's a lot of them. And
> > many are unlikely to be tested in multi-threaded anger during initial
> > development (and MT issues can be hard to unit test). Can you explain a
> > bit further what would be the impact for typical driver styles? Can we
> > make the typical case (no/locked multithreaded access) really easy? What
> > sort of driver code would be needed for drivers that can do MT reads? MT
> > reads and writes?
> I completely understand the being wary about making drivers more complex,
> there are a ton of them and I had to edit every single one for my
> implementation of Solution 2. However, I am starting to like this solution
> more and more. The reason that this solution must be this way, is because
> many drivers will call the same block from different bands. This can cause
> deadlocks if not careful because two threads on the same dataset could be
> in the same processes at different times. To fix this I am passing a mutex
> through the IReadBlock, IWriteBlock, and IRasterIO functions. This allows
> for a much more fine level of control over the process. It allows the mutex
> used to protect the Block Data pointer (that is passed through the
> IReadBlock, etc) to be protected only at the times required. For many
> drivers its simply blocking the entire time the reading/writing process is
> occuring.
> Multi-threading reads should be possible in many cases as long as the
> driver code itself is safe for such an implementation. If a locking is used
> to protect the file pointer and only allow a single thread to be reading
> the file from disk at a time in most drivers they should become thread safe
> (also the protection of any global statics in the drivers). This means
> increased complexity in most drivers to make them thread safe, but I think
> it would be possible.
The question is : how many drivers do not require a global lock in their
IReadBlock() implementation ?
Just throwing an idea : how about a IReadBlock_thread_safe and IReadBlock
virtual methods ? The first one would have a default implementation in
GDALRasterBand that would basically call the second one with a global mutex.
That way drivers that wan't a more fine grained locking could implement their
own IReadBlock_thread_safe, whereas the ones that don't care would just
implement IReadBlock. The few current call sites of IReadBlock would just need
to be updated to call IReadBlock_thread_safe instead.
> Multi-threading writes is a little more complex, and is not well covered in
> these changes. Issues can come up with reading and writing at the same
> time. Here is an example of a complex situation.
> Thread 1: Writes to Block A located at (0,0), this block is then marked for
> deletion from the cache and is intended to be flushed.
> Thread 1: Removes Block A from the Band's block array
> Thread 2: Attempts to Read Block at (0,0). Not finding any blocks it
> creates Block B and inserts it to Band Block Array
> Thread 2: Reads from the driver and loads data into Block B.
> Thread 1: Writes data from Block A which is being flushed to the driver.
> Thread 2: Edits Block B, but incorrectly because the changes from Block A
> are not included.
> I think that this can be corrected in the code by always requiring that all
> flushing through the driver occurs prior to removing the block from the
> block array. Just checked my code and this is possible right now in
> Solution #2, so it might need to be something that I should fix.
> In a more generally large issue, there are issues with even more simple
> things with writing. Imagine someone warping into a band at the same time a
> fill operation on a band is being executed, if there is no protection it
> would end up with a weird set of values. Personally I think this, is
> something we shouldn't attempt to fix currently as this should just be
> accepted as a bad way to write a multi-threaded application.
Agreed.
> If you can
> think of any other situations where writing might have issues I really
> would like to know.
> Thanks,
> Blake
http://www.spatialys.com
