[gdal-dev] Converting MDB File With Unicode Characters
Even Rouault even.rouault at spatialys.com
Mon Aug 25 06:05:44 PDT 2014
Selon Tomer <tomerlieber at gmail.com>:
> i tried the vector utility program "ogr2ogr" to convert mdb to kml and still
> non-English characters are replaced by '?'
So the problem is likely in the ODBC driver that doesn't return UTF-8 encoding.
http://osgeo-org.1560.x6.nabble.com/Converting-MDB-File-With-Unicode-Characters-tp5158087p5158156.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
