[gdal-dev] Rasdaman VRT generation script
Even Rouault even.rouault at spatialys.com
Mon Aug 25 07:06:28 PDT 2014
Selon Fabian Schindler <fabian.schindler at eox.at>:
> Hi folks,
> I created a small script that generates VRT files that act as wrappers
> to add georeferencing to rasdaman arrays (which do not have this feature).
> I thought I could add this somewhere under "/swig/python/samples/", or
> is this too specific for a certain driver?
Looks reasonable. There are fairly specific samples in there already.
For the sake of my curiosity, how is it different than using gdal_translate -of
VRT -a_srs -a_ullr ? Is there anything specifically Rasdaman-ish in the script ?
Even
http://www.spatialys.com
