[gdal-dev] Error when trying to compress a TIFF file
Hanlie Pretorius hanlie.pretorius at gmail.com
Tue Aug 26 06:54:23 PDT 2014
I'm trying to convert a 16 bit image to 8 bits and at the same time
add JPEG compression, but gdal reports errors during the process.
gdal_info for the input file is:
Driver: GTiff/GeoTIFF
Files: D:/SPOT 6/PS_Envi/Test_8bit.TIF
Size is 30717, 28629
Coordinate System is:
PROJCS["WGS 84 / UTM zone 34S",
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",21],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",10000000],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AUTHORITY["EPSG","32734"]]
Origin = (537234.000000000000000,6296730.000000000000000)
Pixel Size = (1.500000000000000,-1.500000000000000)
Metadata:
AREA_OR_POINT=Area
Band_1=CN Sharp R (Band 3:IMG_SPOT6_MS_201304220815274_ORT_742338101_R1C1.TIF)
Band_2=CN Sharp G (Band 2:IMG_SPOT6_MS_201304220815274_ORT_742338101_R1C1.TIF)
Band_3=CN Sharp B (Band 1:IMG_SPOT6_MS_201304220815274_ORT_742338101_R1C1.TIF)
Image Structure Metadata:
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( 537234.000, 6296730.000) ( 21d24' 2.56"E, 33d28' 5.67"S)
Lower Left ( 537234.000, 6253786.500) ( 21d24' 9.04"E, 33d51'20.01"S)
Upper Right ( 583309.500, 6296730.000) ( 21d53'47.54"E, 33d27'56.33"S)
Lower Right ( 583309.500, 6253786.500) ( 21d54' 2.03"E, 33d51'10.53"S)
Center ( 560271.750, 6275258.250) ( 21d39' 0.30"E, 33d39'39.04"S)
Band 1 Block=30717x1 Type=Byte, ColorInterp=Red
Description = CN Sharp R (Band
Band 2 Block=30717x1 Type=Byte, ColorInterp=Green
Description = CN Sharp G (Band
Band 3 Block=30717x1 Type=Byte, ColorInterp=Blue
Description = CN Sharp B (Band
The command I'm using is:
gdal_translate -ot Byte -of GTiff -scale 0 4905 0 255 -stats -co
COMPRESS=JPEG "D:/SPOT 6/PS_Envi/Test.TIF" "D:/SPOT
6/PS_Envi/Test_8bit_JPEG_Compr.TIF"
The last part of the error message is:
ERROR 1: IReadBlock failed at X offset 18, Y offset 2
ERROR 1: VRTSourceRasterBand::iRatserIO() called recursively on the
same band. It looks like the VRT is referencing itself.
ERROR 1: IReadBlock failed at X offset 19, Y offset 2
More than 1000 errors or warnings have been reported. No more will be
reported from now.
0...10...20...30...40...50...60...70...80...90...100 - done.
gdal_translate does complete the process and I get an output file that
looks usable, but I think something is wrong with the file because
working with it in QGIS takes longer than the original image, which is
two orders of magnitude bigger in file size.
gdal_info for the output file is:
Files: D:/SPOT 6/PS_Envi/Test_8bit_JPEG_Compr.TIF
D:/SPOT 6/PS_Envi/Test_8bit_JPEG_Compr.TIF.aux.xml
GEOGCS["WGS 84",
DATUM["WGS_1984",
UNIT["metre",1,
Metadata:
AREA_OR_POINT=Area
COMPRESSION=JPEG
INTERLEAVE=PIXEL
Corner Coordinates:
Band 1 Block=30717x16 Type=Byte, ColorInterp=Red
Band 2 Block=30717x16 Type=Byte, ColorInterp=Green
Band 3 Block=30717x16 Type=Byte, ColorInterp=Blue
Does anybody perhaps know what is going wrong or can suggest another
method to accomplishing what I wish to?
I have successfully created an 8 bit image without using compression,
so I'm pretty sure the error stems from the compression operation.
Regards
Hanlie
