[gdal-dev] How get EPSG code from an OGRSpatialReferenceH?
David Strip gdal at stripfamily.net
Thu Aug 28 20:20:16 PDT 2014
It's my recollection from a question I posted here  a little over a year
ago that except for a few special cases, autoIdentifyEPSG only works if
there is an authority node providing the EPSG. Hopefully someone will
give you an authoritative answer. I believe GeoTools has the capability
to find the EPSG from the WKT, but I have no idea how to interface to that
On 8/28/2014 8:42 PM, Nik Sands wrote:
> Hi devs,
> What is the correct way to extract the EPSG code from an OGRSpatialReferenceH ?
> Currently I'm finding that the following works only for SRS of some images and not others:
> 	const char *charAuthType = OSRGetAttrValue(gdal.srcSRS, "AUTHORITY", 0);
> 	const char *charSrsCode = OSRGetAttrValue(gdal.srcSRS, "AUTHORITY", 1);
> However, there is no "AUTHORITY" node in some SRSs so it doesn't work for those images.  To cater for this, I'm trying to explicitly set the authority node using:
> 	OSRAutoIdentifyEPSG(gdal.srcSRS);
> But this fails with OGRERR_UNSUPPORTED_SRS (even when it is an SRS that GDAL recognises and uses well).
> So I'm stumped... how do I reliably determine the EPSG for an OGRSpatialReferenceH?
> Cheers,
> Nik.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
