[gdal-dev] Convert S57 to image with S52 rendering
s duclos sylvain_duclos at yahoo.com
Fri Aug 29 07:11:45 PDT 2014
Storkur,
Yes, use the call :
S52_dumpS57IDPixels(const char *toFilename, unsigned int S57ID, unsigned int width, unsigned int height);
Check https://github.com/sduclos/S52/blob/master/S52.h for details
rgds,
Sylvain.
On Fri, 8/29/14, Storkur <sovofmad at yandex.ru> wrote:
 Subject: Re: [gdal-dev] Convert S57 to image with S52 rendering
 To: gdal-dev at lists.osgeo.org
 Received: Friday, August 29, 2014, 2:10 AM
 Sylvain Duclos,
 Thanks.
 And is
 there is simple way to automaticaly convert s-57 maps to
 tiled raster
 images with specified scale?
 May be not following s-52 specs.
 View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-Convert-S57-to-image-with-S52-rendering-tp4987897p5158977.html
 Sent
 from the GDAL - Dev mailing list archive at Nabble.com.
 gdal-dev mailing list
 http://lists.osgeo.org/mailman/listinfo/gdal-dev
