[gdal-dev] Problem encountered in stitching/merging the raster files
Andre Joost andre+joost at nurfuerspam.de
Fri Aug 29 07:27:29 PDT 2014
Am 29.08.2014 09:04, schrieb user_name:
> I've tried your suggestion but then the result was this:
> Note: I used OpenEV to open the file.
Perhaps you should switch to QGIS. OpenEV is quite old, and may not work
with all output of GDAL. The grey parts between the images should have NODATA value.
HTH,
André Joost
