[gdal-dev] shp - inconsistent extent
Even Rouault even.rouault at spatialys.com
Wed Dec 3 02:49:39 PST 2014
Le mercredi 03 décembre 2014 11:43:28, Martin Landa a écrit :
> 2014-12-03 11:44 GMT+01:00 Even Rouault <even.rouault at spatialys.com>:
> > If your script only does CreateFeature() to build a shapefile from
> > scratch, then it is really annoying that ArcGIS protests, and we should
> > fix that. But no idea what would cause it.
> it creates shapefile from scratch... Martin
Hum, could you "fix" / "repair" / "save as" the shapefile with ArcGIS, whatever
it offers so it can generate a shapefile on which it doesn't protest anymore ?
That way we could compare the difference between shapefiles. The 100 first bytes
of .shp and .shx must be the key.
http://www.spatialys.com
