[gdal-dev] GDAL Image Viewer supporting extensions
Ledoux, Bruno Bruno.Ledoux at astrium.eads.net
Wed Dec 3 07:16:02 PST 2014
Hi All,
We have developed a Gdal plug-in that supports our proprietary image file format.
We would now like to use a standard visualizer build on Gdal to view our images with minimum development effort.
>From what I have read about geotools there is a substantial amount of code to write in order to integrate a new format. Are there any other visualization libraries or tools that would do this natively without any development ?
Best Regards,
Bruno
[cid:imagea25d47.JPG at 9e8f00e9.4eb1be96] Please consider the environment before printing this email message.
Ce courriel (incluant ses éventuelles pièces jointes) peut contenir des informations confidentielles et/ou protégées ou dont la diffusion est restreinte. Si vous avez reçu ce courriel par erreur, vous ne devez ni le copier, ni l'utiliser, ni en divulguer le contenu à quiconque. Merci d'en avertir immédiatement l'expéditeur et d'effacer ce courriel de votre système. Airbus DS Geo décline toute responsabilité en cas de corruption par virus, d'altération ou de falsification de ce courriel lors de sa transmission par voie électronique.
This email (including any attachments) may contain confidential and/or privileged information or information otherwise protected from disclosure. If you are not the intended recipient, please notify the sender immediately, do not copy this message or any attachments and do not use it for any purpose or disclose its content to any person, but delete this message and any attachments from your system. Airbus DS Geo disclaims any and all liability if this email transmission was virus corrupted, altered or falsified.
Airbus DS Geo SA (325 089 589 RCS Toulouse) - Siege social: 5, rue des Satellites, 31400 Toulouse, France.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20141203/d4b2e976/attachment-0001.html>
Type: image/jpeg
Desc: imagea25d47.JPG
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20141203/d4b2e976/attachment-0001.jpe>
