[gdal-dev] VICAR format
K.-Michael Aye kmichael.aye at gmail.com
Thu Dec 4 14:13:40 PST 2014
  I’m not sure now if this image (‘N1467346388_2_CALIB.IMG’) is actually a VICAR image.
The unix `file` command recognizes it as a VICAR image:
❯ file N1467346388_2_CALIB.IMG                                                           [3:12:31 PM]
N1467346388_2_CALIB.IMG: VICAR image data
but NASAView’s full label view shows me this:
OBJECT = IMAGE_HEADER<CR><LF>
      INTERCHANGE_FORMAT = ASCII<CR><LF>
      HEADER_TYPE = VICAR2<CR><LF>
      BYTES = 4096<CR><LF>
      RECORDS = 1<CR><LF>
      DESCRIPTION = "Original VICAR2 header, updated by CISSCAL.”<CR><LF>
So this sounds like maybe a previous VICAR image has been converted to a more standard PDS format?
Maybe Trent knows more about this.
Michael
  — Michael Aye
Cassini UVIS and MAVEN IUVS team
LASP, Boulder CO
> On Dec 4, 2014, at 2:47 PM, K.-Michael Aye <kmichael.aye at gmail.com> wrote:
> Apparently, the PDS reader works in this case, not sure if it would work on all VICAR images?
> Currently I’m trying to read Cassini ISS images and before I made the mistake to provide the .IMG file instead of the .LBL file to the reader.
> Opening the .LBL label file (that links to the .IMG file) is successful and I get the image out of it. I have confirmed via ds.GetDriver().GetDescription() that the PDS GDAL driver opened the file.
> Michael
> — Michael Aye
> LASP, Boulder CO
>> On Dec 4, 2014, at 12:23 PM, Hare, Trent <thare at usgs.gov> wrote:
>> Michael,   Yes - Sebastian Walters created one. I'm not clear if the driver will be pushed into the public version of GDAL? I know it is being used by the HRSC Team to convert to their VICAR products to GeoTiff (DEMs) and Jpeg2000.(images). If it does get pushed into GDAL then I would recommend the gdal/frmts/pds/ directory alongside other like formats.
>> see page: 185
>> http://pubs.usgs.gov/of/2014/1056/pdf/ofr2014-1056.pdf
>> from: http://pubs.er.usgs.gov/publication/ofr20141056
>> Probably worth asking Sebastian his intentions.
>> Regards,
>> Trent
>> On Thu, Dec 4, 2014 at 12:21 PM, Frank Warmerdam<warmerdam at pobox.com
>>>wrote:
>>> Michael,
>>> I thought it existed, but digging around in the formats directory it appears not to.  It would be nice to add.
>>> Best regards,
>>> Frank
>>> On Thu, Dec 4, 2014 at 11:12 AM, K.-Michael Aye<kmichael.aye at gmail.com
>>>>wrote:
>>>> Hello all,
>>>> Has anybody worked on implementing a VICAR reader yet?
>>>> http://www-mipl.jpl.nasa.gov/external/vicar.html
>>>> It’s pretty important for a bit older NASA data.
>>>> Regards,
>>>> Michael
>>>> — Michael Aye
>>>> LASP, Boulder CO
>>>> _______________________________________________
>>>> gdal-dev mailing list
>>>> gdal-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>> I set the clouds in motion - turn up   | Frank Warmerdam,warmerdam at pobox.com
>>> light and sound - activate the windows |http://pobox.com/~warmerdam
>>> and watch the world go round - Rush    | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20141204/82aff286/attachment-0001.html>
