[gdal-dev] OGR support for Google Latitude KML output
Even Rouault even.rouault at spatialys.com
Thu Dec 4 15:17:12 PST 2014
Le vendredi 05 décembre 2014 00:11:44, Ulrich Strötz a écrit :
> Thanks Even for getting on this so quickly!
> I built GDAL from source after you committed your changes, though I still
> only get the start and end point. Did you try it with my sample file?
Yes, I did. Are you compiling against libkml ?
When running ogrinfo on the file it should display :
INFO: Open of `in.kml'
      using driver `LIBKML' successful.
If it displays "using driver `KML' successful", then you're using the 'old'
KML driver, and gx:Track/MultiTrack won't be recognized.
Even
> Thanks,
> Uli
> > On Dec 4, 2014, at 10:07, Even Rouault <even.rouault at spatialys.com>
> > wrote:
> > Le mercredi 03 décembre 2014 19:53:44, Ulrich Strötz a écrit :
> >> Hi everyone,
> >> I am trying to use ogr2ogr with a KML file generated by Google My Tracks
> >> <https://play.google.com/store/apps/details?id=com.google.android.maps.m
> >> yt racks&hl=en>.
> >> There was a ticket #5095 <http://trac.osgeo.org/gdal/ticket/5095> about
> >> this which is marked as fixed, but it still does not work properly.
> >> I use GDAL 1.11.1, released 2014/09/24 and the following command:
> >> ogr2ogr -f "GeoJSON" out.geojson in.kml
> >> It does create only the start and end points of the track, but not the
> >> points in between.
> >> The sample file can be found here.
> >> https://www.dropbox.com/s/ilafup4m0vcvmxj/in.kml?dl=0
> >> <https://www.dropbox.com/s/ilafup4m0vcvmxj/in.kml?dl=0>
> >> Any help on how to get this to work is appreciated.
> > Ulrich,
> > Ticket 5095 was about gx:Track, but the geometry in your file is a
> > gx:MultiTrack. I've just added support for the later in the LIBKML driver
> > in GDAL trunk.
> > Even
http://www.spatialys.com
