[gdal-dev] shp - inconsistent extent
Martin Landa landa.martin at gmail.com
Tue Dec 9 01:33:44 PST 2014
2014-12-03 11:49 GMT+01:00 Even Rouault <even.rouault at spatialys.com>:
> Hum, could you "fix" / "repair" / "save as" the shapefile with ArcGIS, whatever
> it offers so it can generate a shapefile on which it doesn't protest anymore ?
unfortunately ArcGIS is not able to fix such shapefile, repair
geometry tool fails with "ERROR 001143: Background server threw an
exception."...
> That way we could compare the difference between shapefiles. The 100 first bytes
> of .shp and .shx must be the key.
Broken shapefile can be found [1]. Thanks, Martin
[1] http://geo1.fsv.cvut.cz/landa/parcely.zip
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.eu/mentors/landa
