[gdal-dev] Can't get gdal_rasterize to work... with anything.
Ari Jolma ari.jolma at gmail.com
Sat Dec 13 01:18:08 PST 2014
Karen,
For example this command on my computer
gdal_rasterize -burn 1 -l is50v_mannvirki_flakar_24122013 -of GTiff -ts
1000 1000 is50v_mannvirki_flakar_24122013.shp x.tiff
produces a 1000 x 1000 geotiff which is mostly zeros except ones where
the polygons are.
Can you tell us what command did you use?
Ari
ps: the website was a bit difficult to use for non-icelanders.
13.12.2014, 06:18, Karen Pease kirjoitti:
> Hi all,
> I'm running Fedora 21 with a fresh built gdal-1.9.2. Try as I might, I
> can't get gdal_rasterize to output anything other than purely
> transparent images, purely white images, or purely black images.
> I want to use it on this dataset - "Elevation data. GDB og SHP.
> ISN2004":
> http://atlas.lmi.is/LmiData/index.php?id=1079838344912
> I've spent maybe 8 hours on this, including trying all sorts of
> different commandlines. After finding that I couldn't get that to work,
> I found some sample tutorials that includes a shp file and some command
> lines to use it with gdal_rasterize:
> http://disc.sci.gsfc.nasa.gov/dataholdings/?q=recipes/How-to-Obtain-a-Shapefile-based-Data-Subset-with-GrADS
> http://www.openforis.org/OFwiki/index.php/Special:WhatLinksHere/Example_data_set
> None of these work for me either (using it exactly as they say to), so I
> don't think it's my shp files that's the problem; I think it's
> gdal_rasterize or something it depends on. I know the problem isn't an
> image viewer problem either - I've tried multiple viewers, and I've
> tried saving the files to PNM to allow for manual inspection - they all
> contain only the same data value repeated over and over, no variation,
> just pure one color.
> What should I do? I really need to make a heightmap out of this
> landscape data for inclusion into a 3d model...
>   - kv, Karen
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
