[gdal-dev] GDAL Utilities: Keeping output format identical to input format
Even Rouault even.rouault at spatialys.com
Mon Dec 15 03:36:40 PST 2014
Le lundi 15 décembre 2014 12:27:34, Zoltan Szecsei a écrit :
> On 2014/12/15 12:53, Even Rouault wrote:
> > See http://www.gdal.org/gdal_edit.html
> Hi Even,
> I had a look at gdal_edit but could not get it to work on the server as
> it is Ubuntu 12.04, so first I need to work out how to fix the gdal
> installation on there.
>     *zls at gs0:/mnt/geo_lvm0/gisdata/raster/orthos$* gdalinfo --version
>     GDAL 1.9.1, released 2012/05/15
>     *zls at gs0:/mnt/geo_lvm0/gisdata/raster/orthos$* gdal_edit.py --version
>     Traceback (most recent call last):
>        File "/usr/bin/gdal_edit.py", line 33, in <module>
>          from osgeo import gdal
>        File "/usr/lib/python2.6/dist-packages/osgeo/__init__.py", line
>     21, in <module>
>          _gdal = swig_import_helper()
>     17, in swig_import_helper
>          _mod = imp.load_module('_gdal', fp, pathname, description)
>     ImportError: /usr/local/lib/libgdal.so.1: undefined symbol:
> GEOSSimplify *zls at gs0:/mnt/geo_lvm0/gisdata/raster/orthos$*
Looks like your GDAL has been compiled against a GEOS version and you run it
against another (older) one.
Or you have a mix of GDAL versions.
> I am using the following (instead of gdal_edit) but was wondering if my
> band pixels were being altered.
Yes they will as you use a lossy compression.
>     gdal_translate -a_srs +proj="tmerc +lat_0=0 +lon_0=19 +k=1 +x_0=0
>     +y_0=0 +axis=wsu +ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +units=m
>     +no_defs" -co "COMPRESS=JPEG" -co "PHOTOMETRIC=YCBCR"
>     3121DA_09_2011_407_RGB_RECT.tif 3121da09.tif
> Then because the gdal_translate strips out the overviews:
>       gdaladdo --config COMPRESS_OVERVIEW JPEG --config
>     PHOTOMETRIC_OVERVIEW YCBCR --config INTERLEAVE_OVERVIEW PIXEL
>     3121da09.tif 2 4 8 16 32 64 128 256 512
> So, I was looking at a 1-step way of doing the above, ideally without
> having to manually peek into an adjoining sheet to get the correct proj.
> *This is what I am aiming at:*
> I have about 40000 of these images, and I have written a BASH with awk
> script  to go through all the images and pull out certain info to build
> a CSV file so that I can create attributed polygons to have info about
> the underlying raster image. When this awk script fails to find embedded
> proj info, it would be nice to make it peek into the adjoining ortho,
> extract the relevant info, and edit it into the 'bad' ortho.
gdal_edit is really what you want. Will be much faster than
gdal_translate+gdaladdo and will not alter pixel values.
> Thanks again for your help.
> Kind regards,
> Zoltan
http://www.spatialys.com
