[gdal-dev] Reg: Error while running Kartograph which uses gdal
Manikanta Kondeti mani.iiit123 at gmail.com
Wed Dec 17 10:33:42 PST 2014
Hi all,
I'm trying to install kartograph, it's a library which converts shapefiles
to svg.  Everything is installed without errors. While running kartograph
I'm getting this following error - [1] which is related to gdal.
[1] -- * ImportError: /usr/lib/python2.7/dist-packages/osgeo/_gdal.so:
symbol GOA2GetRefreshToken, version GDAL_1.8 not defined in file
libgdal.so.1 with link time reference*
I will be happy if anyone can guide me or explain me the reason
Thanks,
Manikanta
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20141218/612b9951/attachment.html>
