[gdal-dev] Garmin .img data?
Paolo Cavallini cavallini at faunalia.it
Fri Dec 19 08:39:40 PST 2014
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi Even,
Il 19/12/2014 17:01, Even Rouault ha scritto:
> Probably perhaps nobody has written it. The link you gave doesn't
> link much information about the format. Is it the vector format
> described at http://sourceforge.net/projects/garmin-
> img/?source=typ_redirect ? If so, a quick skimming of it would lend
> me thinking that read support should be possible, although likely
> not a trivial effort (41 pages for an unformal specification is
> quite significant). Write support and interoperability with Garmin
> devices would probably be harder as I can see quite a few ??? in
> the document.
thanks for your reply. I imagined this, but I was surprised by the
fact that apparently small projects were able to read the format
without much difficulty.
Going to ask qmapshack dev.
All the best.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1
iEYEARECAAYFAlSUVMsACgkQ/NedwLUzIr5giQCfYPrUmAapyobGIMzMQg/oN7Su
3GsAoJrfbXiCJGezXuzy7jeTAPyQlDzV
=qovP
-----END PGP SIGNATURE-----
