[gdal-dev] Can't make GME driver work
Jorge Arévalo jorge at cartodb.com
Sat Dec 20 03:25:39 PST 2014
Hi Wolf
I already fixed it. I had to follow these steps:
- Define GOA2_CLIENT_ID, GOA2_CLIENT_SECRET, GME_APIKEY
- Define GME_REFRESH_TOKEN, which allow the app to refresh the token
No problem, so far. Just followed this
http://trac.osgeo.org/gdal/wiki/GMEDriver
- Define GME_AUTH (or provide 'auth' in the query string). This is not
specified in the wiki page, but can be found here:
https://github.com/OSGeo/gdal/blob/trunk/gdal/ogr/ogrsf_frmts/gme/ogrgmedatasource.cpp#L140
The steps to get those environment vars are:
- GOA2_CLIENT_ID, GOA2_CLIENT_SECRET, GME_APIKEY --> from Google API console
- GME_AUTH, GME_REFRESH_TOKEN --> execute gdal_auth.py. Also stated in the
wiki page. Just use the interactive option.
gdal_auth.py -s gme
So, the wiki page is basically correct. But just need to add the part about
GME_AUTH :-)
Best regards,
Jorge
El 19/12/2014 18:33, "Wolf Bergenheim" <wolf+grass at bergenheim.net> escribió:
> Hi Jorge.
> I noticed some issues with it earlier this week. I'll see if I have some
> spare time over the weekend to see what I can do about it. Are you using
> the trunk version or an earlier release?
> On 18 December 2014 at 23:23, Jorge Arévalo <jorge at cartodb.com> wrote:
>>  Hello,
>> I'm having problems making the GDAL GME driver work (
>> http://trac.osgeo.org/gdal/wiki/GMEDriver). I've defined CLIENT_API and
>> CLIENT_SECRET in Google API console, and I successfully used them with the
>> QGIS GME plugin (
>> https://plugins.qgis.org/plugins/GoogleMapsEngineConnector/) and with
>> the example Python script of the doc page:
>> https://developers.google.com/maps-engine/documentation/oauth/installedapplication.
>> But, for some reason, I keep getting HTTP 401 error when trying to read
>> from my GME account using the GDAL driver.
>> I've used gdal_auth.py to get the access token and the refresh token.
>> Passed the config options, as stated in the driver's page. Always getting
>> HTTP 401.
>> Do you have any working example using GDAL GME driver? More info about my
>> problem here:
>> http://gis.stackexchange.com/questions/127065/i-cant-configure-authentication-with-google-maps-engine-driver-from-gdal
>> Many thanks in advance!
>> Jorge
>> Sent using Postbox:
>> http://www.getpostbox.com
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20141220/96867cd3/attachment.html>
