[gdal-dev] What is the maximum '-wm' I can use with 64bit gdalwarp?
Even Rouault even.rouault at spatialys.com
Wed Dec 24 02:30:46 PST 2014
Le mercredi 24 décembre 2014 11:19:14, Simen Langseth a écrit :
> Dear Even Rouault
> Thanks for your answer.
> When I used more than 1024 mb for sub-sampling an image, strangely with in
> few minutes, a completely black image is produced.
Hum, I'm just fixing a but wher putting more in -wm caused issue but it was
very specific : http://trac.osgeo.org/gdal/ticket/5789
> Using 1024 is not sufficient because my input file is around 300GB.
Eh, read again what I wrote : "putting more warp memory will not necessarily
need to more performance". -wm is the size of individual chunks that will be
warped. Working on very big chunks is actually detrimental if you want to use
-multi since there will be less opportunity to parallelize I/O and CPU bound
operations.
If not already done, you'll get probably much more performance by for example
ensuring you output to a tiled GeoTIFF, by adding -co TILED=YES
> I could
> not figure out the problem. I am also using '-multi' parameter.
> There is no problem if I do not use '-wm' and '-multi' parameters or just
> use 1024 with '-wm' and '-multi' except very slowness.
> I hope you can help me.
> Simen
> On Wed, Dec 24, 2014 at 6:50 PM, Even Rouault <even.rouault at spatialys.com>
> wrote:
> > Simen,
> > Up to 9999 for 9999 MB. And if you want more, you have to specified the
> > value
> > in bytes instead of megabytes.
> > But putting more warp memory will not necessarily need to more
> > performance, especially if you mosaic many small images into a big one.
> > See
> > https://trac.osgeo.org/gdal/wiki/UserDocs/GdalWarp#WillincreasingRAMincre
> > asethespeedofgdalwarp
> > Even
> > Spatialys - Geospatial professional services
> > http://www.spatialys.com
