[gdal-dev] Is user document about gdalwarp still good?
Even Rouault even.rouault at spatialys.com
Fri Dec 26 03:42:49 PST 2014
Le vendredi 26 décembre 2014 12:09:29, Jukka Rahkonen a écrit :
> Hi,
> There is a user document about gdalwarp in the wiki
> http://trac.osgeo.org/gdal/wiki/UserDocs/GdalWarp. However, it is a bit old
> with references to GDAL 1.7.2. I would like to add a link to this document
> into gdalwarp manual page http://www.gdal.org/gdalwarp.html but I wonder if
> there is something to update in the wiki document first.
> It would be nice is gdalwarp specialists could check the wiki doc and
> comment if it contains some outdated information.
Was mostly good. I've done some small updates.
Some behaviours slightly change/improve between versions.
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
