[gdal-dev] Is user document about gdalwarp still good?
Even Rouault even.rouault at spatialys.com
Fri Dec 26 06:16:34 PST 2014
Le vendredi 26 décembre 2014 15:09:23, Jukka Rahkonen a écrit :
> Even Rouault <even.rouault <at> spatialys.com> writes:
> > Le vendredi 26 décembre 2014 12:09:29, Jukka Rahkonen a écrit :
> > > Hi,
> > > There is a user document about gdalwarp in the wiki
> > > http://trac.osgeo.org/gdal/wiki/UserDocs/GdalWarp. However, it is a bit
> > > old with references to GDAL 1.7.2. I would like to add a link to this
> > > document into gdalwarp manual page http://www.gdal.org/gdalwarp.html
> > > but I wonder if there is something to update in the wiki document
> > > first.
> > > It would be nice is gdalwarp specialists could check the wiki doc and
> > > comment if it contains some outdated information.
> > Was mostly good. I've done some small updates.
> > Some behaviours slightly change/improve between versions.
> Thanks. I have to say that after browsing the sources for a good while I
> have still no idea what to edit for adding section "See also" and a link to
> the wiki document to gdalwarp utility page
> http://www.gdal.org/gdalwarp.html.
Ah indeed, the documentation of that utility is located in the source file
itself of gdalwarp (quite an exception) in apps/gdalwarp.cpp
Links can be done with the standard HTML <a> tag
> -Jukka-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
