[gdal-dev] Is user document about gdalwarp still good?
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Fri Dec 26 07:01:04 PST 2014
Even Rouault <even.rouault <at> spatialys.com> writes:
> Ah indeed, the documentation of that utility is located in the source file
> itself of gdalwarp (quite an exception) in apps/gdalwarp.cpp
> Links can be done with the standard HTML <a> tag
I found the documentation section from gdalwarp.cpp but adding new items
there does not make me feel comfortable so that is "wontfix" from my part.
-Jukka-
