[gdal-dev] How to fix gdalwarp warning?
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Fri Feb 7 07:07:46 PST 2014
Stephen Woodbridge <woodbri <at> swoodbridge.com> writes:
> How does one do "Converting the dataset  prior to 24/32 bit is advised."?
For example with http://www.gdal.org/pct2rgb.html
-Jukka Rahkonen-
