[gdal-dev] [RFC] [GDAL] Idea for GSoC, 2014
Kshitij Kansal kansal.k at gmail.com
Fri Feb 7 14:15:07 PST 2014
Sir
I am providing the links for both the algorithms that I talked. I am new to
this licence issues thing so I would be highly grateful if you can clarify
doubts and if can proceed on working for this idea.
http://www.cs.ubc.ca/~lowe/keypoints/ (SIFT)
http://www.ipol.im/pub/art/2011/my-asift/ (ASIFT) [here source code is
provided. It contains license ]
http://www.cmap.polytechnique.fr/~yu/research/ASIFT/demo.html (Demo Page
for ASIFT)
The SIFT algorithm in itself is patented. They only provide binaries. I am
not sure If we can use those binaries or not.
As far as ASIFT is concerned, i think its implementation is only patented.
Kindly clarify this.
Thanking You
With Regards,
Kshitij Kansal
Lab For Spatial Informatics,
IIIT Hyderabad
On Sat, Feb 8, 2014 at 2:23 AM, Even Rouault
<even.rouault at mines-paris.org>wrote:
> Selon Kshitij Kansal <kansal.k at gmail.com>:
> Kshitij,
> I'm surprised that you mention licenses
> for algorithms. What are your sources for that?
> Only *implementations* can be licensed
> not algorithms themselves. So if you
> develop your own implementation you are free
> to select the license you wish. There
> might be issues linked to potential pattents
> in some countries but that is acceptable in my opinion
> as software parents are not valid in all contries
> so mentionning potential issues with them
> in the documentation is sufficient .
> > Hello
> > Based on all suggestion
> ins and comments above, I have come up with one thing.
> > The most important thing that could have been a road block for this
> project
> > was licence issues which was pointed by Even Rouault.
> > I am interested in implementing the SIFT or ASIFT algorithms for
> automatic
> > geo-referencing which I proposed in above mails. I am interested in
> making
> > a separate tool which will be completely based on the GDAL and maintained
> > by GDAL community. I looked into the GDAL-correlator idea which was also
> > implemented as a part of GSoC. That idea uses only *SIMPLE SURF
> *algorithm
> > for control point detection and is only *limited to small size three band
> > imagery(RGB)*.
> > I am interested in developing something that is fully automated and works
> > on large multi band imagery.But the above two algorithms that I am
> planning
> > to use come up with the licence that does not allows the free use for
> > commercial purposes. The free use of above algorithm are restricted to
> *"non
> > profit research and non profit educational purposes"*(in case of
> > ASIFT) and *"research
> > purposes only" *(in case of SIFT).
> > This means that the final product as a result of this product will also
> be
> > bounded by the above licences. It can not go into GDAL's main
> distribution
> > but can be used as a separate utility of GDAL for non-commercial uses
> only.
> > Basically the commercial use of the tool won't be allowed without
> approval
> > from the concerned people.
> > Your views and suggestions are highly appreciated.
> > Regards,
> > Kshitij Kansal
> > IIIT Hyderabad
> > On Thu, Jan 30, 2014 at 12:25 PM, Kshitij Kansal <kansal.k at gmail.com>
> wrote:
> > > Hello
> > > @Jukka Rahkonen: The OSSIM project (the link you provided) is more of
> > > image orthorectification. Although
> > > they are doing image co-registration but its as one of the steps of
> > > orthorectification(I could only understand this from the manual).
> > > Also I am not sure of the techniques they are using for this purposes.
> > > (Its written corner point detection but How?)
> > > I am new to OSSIM, so not aware of this thing's functionality and
> > > accuracy. I am in the process of estimating it.
> > > Thank you for pointing this out.
> > > Coming to the Frank Warmerdam's blog (http://fwarmerdam.blogspot.fi/).
> > > Here the author is talking about writing a code for converting the
> GCP's
> > > into RPC's. But the next question comes is where is he getting GCP's
> from.
> > > Now this is the part where I aim to work on and improve.
> > > Given two images, if we can automatically extract GCP's from them then
> we
> > > are in a way speeding up and automating this whole process. Once we
> have
> > > GCP, there are a lot of things that we can do from them like
> > > geo-referencing(which I plan on doing), image stitching etc.
> > > *Also you talked about a "more light weighted system". Can you please
> > > elaborate on this?* I could not understand what you actually meant from
> > > that.
> > > If we look into the last year idea's page (
> > > http://trac.osgeo.org/gdal/wiki/SummerOfCode), there is one idea that
> is
> > > proposed regarding the "Raster/Vector geo-referencer on the Web". I
> want to
> > > modify this idea a little bit and want to automate the whole process.
> As
> > > far as the automation is concerned, we can develop GDAL functions for
> > > that(which will be completely re-usable) and then developing a Web
> based
> > > geo-referencer would only require calling those functions.
> > > If we do this thing,* two objectives will be fulfilled*.* First*, GDAL
> > > will get a web based geo-referencer. *Secondly*, communities that use
> > > GDAL and have not developed these kind of geo-referencer(Like QGIS) can
> > > directly use the functions developed and then build on that.
> > > Suggestions and comments are welcomed.
> > > Thank you for your propositions.
> > > Regards,
> > >  Kshitij Kansal
> > > IIIT Hyderabad
> > > On Wed, Jan 29, 2014 at 1:27 PM, Jukka Rahkonen <
> jukka.rahkonen at mmmtike.fi
> > > > wrote:
> > >> Kshitij Kansal <kansal.k <at> gmail.com> writes:
> > >> > Even,
> > >> > Thank you for pointing out this issue. I will keep this in mind.
> > >> > I will look into that last year project and try to understand the
> > >> implementation.
> > >> > More suggestions and comments are always welcomed.
> > >> Hi,
> > >> Another OSGeo project OSSIM has implemented an automatic image to
> image
> > >> rectification. Isn't that a bit alike your plan?
> http://download.osgeo.org/ossim/docs/OSSIM_Coregistration_UserManual.pdf
> > >> Frank Warmerdam seems to entertain himself with something related
> > >> This article from 2013 may also give some inspiration
> http://www.academia.edu/4388853/OrientAL_-_Automatic_geo-referencing_and_ortho-rectification_of_archaeological_aerial_photographs
> > >> All these three aim to very high quality and I am sure that there is
> also
> > >> need for a more light-weight system.
> > >> -Jukka Rahkonen-
> > >> _______________________________________________
> > >> gdal-dev mailing list
> > >> gdal-dev at lists.osgeo.org
> > >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140208/86f54792/attachment-0001.html>
