[gdal-dev] gdalwarp EPSG:32662 problem
Stephen Woodbridge woodbri at swoodbridge.com
Sat Feb 8 06:27:11 PST 2014
On 2/8/2014 2:55 AM, Jean-Claude Repetto wrote:
> On 08/02/2014 07:11, Stephen Woodbridge wrote:
>> I've run into a problem that I think is related to a change in the EPSG
>> definition for EPSG:32662
>> The symptom is that the image after gdalwarp reprojection is about 20km
>> south of where it should be.
> Please post the gdalwarp command you have used. (I mean, with both CRS).
> The problem is likely on the other CRS.
gdalwarp -rcs -ts 8800 6600 -s_srs EPSG:32662 -t_srs EPSG:4326
$temptiff1 $target
And the image in question is:
root at u17269306:/maps/images.tmp# gdalinfo
MODIS.2014038.193758.fullpass.seadas_sst.hdf
Driver: HDF4/Hierarchical Data Format Release 4
Files: MODIS.2014038.193758.fullpass.seadas_sst.hdf
Size is 512, 512
Coordinate System is `'
Metadata:
   Collection Location=USF Institute for Marine Remote Sensing
   Data Source Type=Direct Broadcast
   Input File(s)=/tmp/s4p_run_map_modis_2.3_WSthzYwz/A2014038193749.GEO,
/tmp/s4p_run_map_modis_2.3_WSthzYwz/A2014038193749.L2_LAC_SST,
/tmp/s4p_run_map_modis_2.3_WSthzYwz/A2014038194019.GEO,
/tmp/s4p_run_map_modis_2.3_WSthzYwz/A2014038194019.L2_LAC_SST,
/tmp/s4p_run_map_modis_2.3_WSthzYwz/A2014038194249.GEO,
/tmp/s4p_run_map_modis_2.3_WSthzYwz/A2014038194249.L2_LAC_SST,
/tmp/s4p_run_map_modis_2.3_WSthzYwz/A2014038194519.GEO,
/tmp/s4p_run_map_modis_2.3_WSthzYwz/A2014038194519.L2_LAC_SST,
/tmp/s4p_run_map_modis_2.3_WSthzYwz/A2014038194749.GEO,
/tmp/s4p_run_map_modis_2.3_WSthzYwz/A2014038194749.L2_LAC_SST
   L3 Software Name=/usr/bin/map_modis.pl
   L3 Software Version=4.2
   Map Limit=-5, -125, 55, -45
   Map Projection Category=Proj 4.4.7
   Map Projection Name=eqc
   Processing Status=intermediate
   Proj Projection Parameters=#Equidistant Cylindrical (Plate Caree)
#       Cyl, Sph
#       lat_ts=
# +proj=eqc +ellps=WGS84
   Satellite=aqua
   Spatial Resolution=1km
   Temporal Resolution=pass
Subdatasets:
SUBDATASET_1_NAME=HDF4_SDS:UNKNOWN:"MODIS.2014038.193758.fullpass.seadas_sst.hdf":0
   SUBDATASET_1_DESC=[6600x8800] seadas_sst (16-bit integer)
SUBDATASET_2_NAME=HDF4_SDS:UNKNOWN:"MODIS.2014038.193758.fullpass.seadas_sst.hdf":1
   SUBDATASET_2_DESC=[6600x8800] l2_flags (32-bit integer)
Corner Coordinates:
Upper Left  (    0.0,    0.0)
Lower Left  (    0.0,  512.0)
Upper Right (  512.0,    0.0)
Lower Right (  512.0,  512.0)
Center      (  256.0,  256.0)
