[gdal-dev] gdalwarp EPSG:32662 problem
Even Rouault even.rouault at mines-paris.org
Sat Feb 8 15:42:29 PST 2014
I've just tested the 2 definitions with GDAL trunk and proj 4.8.0 and both
definitions give identical results :
$ gdaltransform -s_srs EPSG:4326 -t_srs "+proj=eqc +lat_ts=0 +lon_0=0 +x_0=0
+y_0=0 +ellps=WGS84 +datum=WGS84 +units=m +no_defs +wktext"
2 49
222638.981586547 5454655.04887041 0
$ gdaltransform -s_srs EPSG:4326 -t_srs "+proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0
+x_0=0 +y_0=0 +datum=WGS84 +units=m +no_defs +wktext"
2 49
But Antti guess seems right. Instead of +ellps=WGS84 (or +datum=WGS84), if you
play with the a (semi-major axis) and b (semi-minor axis) parameters, you can
see that only +a has an influence, so latest proj version seems to use a
spherical version of eqc. Reviewing the history of pj_eqc.c (
http://trac.osgeo.org/proj/log/trunk/proj/src/PJ_eqc.c ) I don't see where a
change of behaviour would have happened, but that might be somewhere else in
proj codebase.
> Hi,
> Sorry for cross posting. This seems like a proj4 issue but might be gdal
> related.
> I've run into a problem that I think is related to a change in the EPSG
> definition for EPSG:32662
> The symptom is that the image after gdalwarp reprojection is about 20km
> south of where it should be.
> old system is correctly aligned:
> GDAL 1.4.2.0, released 2007/06/27
> proj Rel. 4.5.0, 22 Oct 2006
> # WGS 84 / Plate Carree
> <32662> +proj=eqc +lat_ts=0 +lon_0=0 +x_0=0 +y_0=0 +ellps=WGS84
> +datum=WGS84 +units=m +no_defs  <>
> new system is shifted about 20km south:
> GDAL 1.9.2, released 2012/10/08
> proj Rel. 4.8.0, 6 March 2012
> # WGS 84 / Plate Carree (deprecated)
> <32662> +proj=eqc +lat_ts=0 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +datum=WGS84
> http://spatialreference.org/ref/epsg/32662/
> This indicates that the definition in proj 4.8.0 is wrong. Would the
> +ellps=WGS84 account for this shift?
> Any thoughts on this?
> Thanks,
>    -Steve
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Geospatial professional services
http://even.rouault.free.fr/services.html
