[gdal-dev] How to fix gdalwarp warning?
Stephen Woodbridge woodbri at swoodbridge.com
Sat Feb 8 16:05:07 PST 2014
On 2/8/2014 6:44 PM, Even Rouault wrote:
> Le vendredi 07 février 2014 16:07:46, Jukka Rahkonen a écrit :
>> Stephen Woodbridge <woodbri <at> swoodbridge.com> writes:
>>> How does one do "Converting the dataset  prior to 24/32 bit is advised."?
>> For example with http://www.gdal.org/pct2rgb.html
> "gdal_translate -expand rgb" or rgba is an alternative.
Thanks Even, I found that after Jukka's post and used that instead.
I appreaciate all the help from the list. You guys are great!
-Steve
