[gdal-dev] Fast Pixel Access
Even Rouault even.rouault at mines-paris.org
Mon Feb 10 15:16:33 PST 2014
Le mardi 11 février 2014 00:10:20, David Baker (Geoscience) a écrit :
> Evan.  I am on Windows and only have the binaries installed.
Well, I let Windows developers lurking here answer if they have some good
advice. I imagine you would need binaries with debugging symbols to be able to
get a usefull stack trace.
> David
> -----Original Message-----
> From: Even Rouault [mailto:even.rouault at mines-paris.org]
> Sent: Monday, February 10, 2014 8:54 AM
> To: David Baker (Geoscience)
> Cc: 'Even Rouault'; 'Brian Case'; 'gdal-dev at lists.osgeo.org'
> Subject: RE: [gdal-dev] Fast Pixel Access
> Selon "David Baker (Geoscience)" <david.m.baker at chk.com>:
> > Even,
> > No not an i386...  A Dell Precision T3500 w/Intel W3680 @ 3.33GHhz 6x2
> > cores with 12.0GB.  Thought the data is on the network, not local, with
> > 1Gbps access.  The GDAL_DISABLE_READDIR_ON_OPEN = TRUE did significantly
> > increase the speed.  Does the BIL driver read the whole file into memory
> > first?  Might a direct read be faster?
> No the BIL driver will just read the line where the pixel is.
> > And Even, please excuse my ignorance, but what is "gdb?"  I really would
> > like to do the profiling.
> gdb is the GNU debugger ( https://www.gnu.org/software/gdb/ ) . Assuming
> you use Linux (likely available on MacOSX too). You should be able to
> install it with the usual package management system of the distribution :
> apt-get install gdb, yum install gdb, ... . Otherwise on Windows, I'm far
> less familiar with the debugging tools.
> gdb --args gdallocationinfo -valonly -geoloc intermap.vrt
> Then type "run"
> Type a coordinate "-96.0 36.0"
> ctrl+c to suspend execution
> "bt" to display the stack trace
> "c" to resume execution
> > David
> > Sent: Sunday, February 09, 2014 6:36 AM
> > Cc: 'Brian Case'; 'gdal-dev at lists.osgeo.org'
> > Subject: Re: [gdal-dev] Fast Pixel Access
> > Le samedi 01 février 2014 15:04:46, David Baker (Geoscience) a écrit :
> > > Evan,
> > > I am not sure how to profile as I do not have access to the code to
> > > profile.  I did do a timing test...
> > > vrt file = 22,970 KB
> > > bil file = 35,180 KB * 55,501
> > > I piped five locations from the loc.txt file:
> > > -96.0 36.0
> > > -98.0 37.0
> > > -100.0 38.0
> > > -99.0 39.0
> > > -101.0 35.0
> > > gdallocationinfo -valonly -geoloc intermap.vrt < loc.txt
> > > 189.841857910156        25.5 sec
> > > 384.857452392578        22.6 sec
> > > 762.015930175781        22.9 sec
> > > 550.719116210938        23.6 sec
> > > 883.637023925781        22.9 sec
> > > Note: I used a lap timer on my iPhone to capture the split times as the
> > > results appeared in the console window.  Does this give any insight?
> > Woo I agree that's utterly slow ! When you mentionned slow I thought it
> > was more in the order of 0.1 second ! We can already exclude the parsing
> > time of the VRT since you do that in the same gdallocationinfo session
> > and that there will be just one parsing.
> > And I can't believe that the intersection test for 55 000 rectangles
> > takes ~ 20 seconds, unless you have an old i386 at 5 MHz ;-)
> > My usual way of profiling stuff that is slow in the order of more than
> > one second is to run under gdb, break with Ctrl+C, display the stack
> > trace, continue the run, break again, display the stack trace, etc.. If
> > you end up breaking in the same function, then you've found the
> > bottleneck.
> > I see now that in that thread GDAL_DISABLE_READDIR_ON_OPEN = TRUE was
> > suggested and seems to improve things significantly. Perhaps we should
> > try to cache the result of the initial readdir so it can benefits to
> > later attempts, but I haven't checked how easily that could be
> > miplemented. Or perhaps we should just change the default value of
> > GDAL_DISABLE_READDIR_ON_OPEN since it causes problem from time to time.
> > But generally filesystems don't behave very well when there are a lot of
> > files
> > in the same directory. You'd better organizing your tiles in
> > subdirectories. But still 1 to 3 seconds sounds a bit slow to me. Would
> > be cool if you could try the above suggestion to identify where the time
> > is spent.
> > Even
> > > David
> > > From: gdal-dev-bounces at lists.osgeo.org
> > > [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Even Rouault
> > > Sent: Saturday, February 01, 2014 1:28 AM
> > > To: Brian Case
> > > Cc: gdal-dev at lists.osgeo.org
> > > Le samedi 01 février 2014 00:23:13, Brian Case a écrit :
> > > > evenr
> > > > what about the use of a tileindex?
> > > You really mean a tileindex as produced by gdaltindex ? Well, that's
> > > not exactly the same beast as a VRT, but yes if it was recognized as a
> > > GDAL dataset then you could potentially save the cost of XML parsing.
> > > One could imagine that the VRT driver would accept a tileindex as an
> > > altenate connection string.
> > > Anyway it would be interesting to first profile where the time is spent
> > > in David use case. If it's in the XML parsing, then I can't see what
> > > could be easily improved in that area. If it's the intersection, then
> > > there's potential for improvement.
> > > > seems an intersection with a set of
> > > > polys first would be quick
> > > > brian
> > > > On Fri, 2014-01-31 at 19:30 +0100, Even Rouault wrote:
> > > > > Le vendredi 31 janvier 2014 17:15:53, David Baker (Geoscience) a
> > > > > écrit
> > > > > > Dev's,
> > > > > > I have a set of 55,501 bil files in a single directory.  They are
> > > > > > DEMS data that cover the US in 7.5 minute tiles.  I would like to
> > > > > > randomly access elevations at a given lat/lon's from the whole
> > > > > > dataset.  I created a vrt file from the directory of bil files,
> > > > > > and have been able to access the elevation at a given lat/lon
> > > > > > using gdallocationinfo, but because of the size of the dataset,
> > > > > > this operation is somewhat slow. Can the vrt be indexed?
> > > > > No, it isn't currently, although I think it could be improved to
> > > > > have a in- memory index with moderate effort.
> > > > > But are you sure the slowness is due to the lack of index ? 55,000
> > > > > is a big number, but not that big. Maybe the slowness just comes
> > > > > from the opening time (XML parsing) of such a big VRT. That would
> > > > > need to be profiled to be sure where the bottleneck is.
> > > > > > Or, is there a faster, better way to access the pixels?  I would
> > > > > > first like to do this with the utilities before diving into code
> > > > > > (C#). The files are regularly named base on their location within
> > > > > > a 1 arc-second grid.
> > > > > > Thanks,
> > > > > > David
> > > > > > David M. Baker
> > > > > > Senior Advisor - Geoscience Technology
> > > > > > Chesapeake Energy Corporation
> > > > > > david.m.baker at chk.com<mailto:david.m.baker at chk.com>
> > > > > > ________________________________
> > > > > > This email (and attachments if any) is intended only for the use
> > > > > > of the individual or entity to which it is addressed, and may
> > > > > > contain information that is confidential or privileged and
> > > > > > exempt from disclosure under applicable law. If the reader of
> > > > > > this email is not the intended recipient, or the employee or
> > > > > > agent responsible for delivering this message to the intended
> > > > > > recipient, you are hereby notified that any dissemination,
> > > > > > distribution or copying of this communication is strictly
> > > > > > prohibited. If you have received this communication in error,
> > > > > > please notify the sender immediately by return email and destroy
> > > > > > all copies of the email (and attachments if any).
> > > Geospatial professional services
> > > http://even.rouault.free.fr/services.html
> > > _______________________________________________
> > > gdal-dev mailing list
> > > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> > > This email (and attachments if any) is intended only for the use of the
> > > individual or entity to which it is addressed, and may contain
> > > information that is confidential or privileged and exempt from
> > > disclosure under applicable law. If the reader of this email is not
> > > the intended recipient, or the employee or agent responsible for
> > > delivering this message to the intended recipient, you are hereby
> > > notified that any dissemination, distribution or copying of this
> > > communication is strictly prohibited. If you have received this
> > > communication in error, please notify the sender immediately by return
> > > email and destroy all copies of the email (and attachments if any).
> > disclosure under applicable law. If the reader of this email is not the
> > intended recipient, or the employee or agent responsible for delivering
> > this message to the intended recipient, you are hereby notified that any
> > dissemination, distribution or copying of this communication is strictly
> > prohibited. If you have received this communication in error, please
> > notify the sender immediately by return email and destroy all copies of
> individual or entity to which it is addressed, and may contain information
> that is confidential or privileged and exempt from disclosure under
> applicable law. If the reader of this email is not the intended recipient,
> or the employee or agent responsible for delivering this message to the
> intended recipient, you are hereby notified that any dissemination,
> distribution or copying of this communication is strictly prohibited. If
> you have received this communication in error, please notify the sender
> immediately by return email and destroy all copies of the email (and
