[gdal-dev] Is there documetation about filters and some python utilities?
Etienne Tourigny etourigny.dev at gmail.com
Sun Feb 16 16:18:58 PST 2014
On Sun, Feb 16, 2014 at 8:36 AM, Jukka Rahkonen
<jukka.rahkonen at mmmtike.fi>wrote:
> Hi,
> I was thinking that a possibility to run images through filters with GDAL
> could be nice sometimes. Especially for visual work with aerial and
> satellite images filters like "sharpen" of "unsharp mask"
> http://en.wikipedia.org/wiki/Unsharp_masking are often very useful. But
> then
> I found that kernel filters can already be used inside VRT files. Are there
> usage examples with before-after comparison images somewhere in our
> documentation?
The only I know of is the vrt tutorial (with very few details), but you
have probably already read that
http://www.gdal.org/gdal_vrttut.html
These refs may help (obtained through a simple google search)
http://homepages.inf.ed.ac.uk/rbf/HIPR2/unsharp.htm
http://stackoverflow.com/questions/2938162/how-does-an-unsharp-mask-work
> I also found that there are some python scripts included in
> \gdal\bin\gdal\python\scripts at least in the gisinternals GDAL builds but
> some scripts are not listed in http://gdal.org/gdal_utilities.html.  Is
> there some other place where to find documentation about these scripts, for
> example gdal_calc.py ? Some other than the sources, I mean.
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140216/e663ca24/attachment.html>
