[gdal-dev] GSoC 2014
Dmitriy Baryshnikov bishop.dev at gmail.com
Mon Feb 17 04:06:07 PST 2014
Hi Mikhai,
Great! Nice to see such interesting to GSoC this year.
Best regards,
     Dmitry
17.02.2014 14:13, ?????? ????? ?????:
> Hello everyone.
> I am a last year student at Moscow Power Engineering Institute,
> Russia. For GSoC 2014 I would like to work on networking capabilities
> in GDAL/OGR.
> _
> _
> _Overall idea_
> I would like to try to implement a universal network model. The
> universality of the model would reflect not only in the ability to use
> different GIS formats to store and transfer network data (which OGR is
> a grate basis for), but also to be able to design and simulate
> different types of network applications (engineering, natural, etc). I
> understand that it is rather ambitious to consider all possible
> aspects of all network types. But as a first step I would like to
> cover only the basic aspects, that can be generalized and to provide a
> "platform" which can be used by other developers to create their own
> extensions which are specific to the concrete network type.
> _Target scope for GSoC 2014_
> Today none of OGR drivers supports network functionality. The idea is
> to implement a new OGR driver, which will deal with networks built
> over the spatial data. The spatial data together with the network data
> will be stored in one of the OGR-supported formats, which would be
> specified during the creation of the network.
> Planned features of the new driver:
> 1. Reading/writing data from/to the source, creating layers, editing
> attributes, etc (as any new OGR driver must provide);
> 2. The user would also be able to do the following, assuming that all
> the special network data is the data of the current GIS-format:
> - Read/Write the information about the whole network (network metadata);
> - Edit special network objects parameters such as blocking state, or
> direction of the flow;
> - Import objects from the external sources (the driver adds missing
> network parameters to them);
> - Set/unset connections among network objects;
> - Edit the sets of the network rules.
> 3. Each object in the network will have a set of relations with other
> objects, which are stored separately and form a network graph;
> 4. The whole network will have a set of rules that describes the
> connection possibilities of different object types in the network. The
> network will also have a set of rules that describes the influence of
> each type of object to the state of the whole network and to the other
> types of objects. It can also be called as a behavior of the object in
> the context of the network specialization (engineering purpose).
> _Current status_
> https://github.com/MikhanGusev/gnm
> As a matter of fact I've been working on this for a while, and I've
> already completed few things. Here is what I've accomplished already:
> 1. Complete. The driver and most of the required virtual interfaces
> are already implemented;
> 2. Complete. All data from the external source is wrapped with the
> network proxy and the user can edit it.
> 3. Currently, I'm thinking about the way, how the network graph will
> be stored.
> Best regards,
> Mikhail Gusev.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140217/2552b587/attachment-0001.html>
