[gdal-dev] GSoC 2014
Even Rouault even.rouault at mines-paris.org
Mon Feb 17 06:56:29 PST 2014
Also of potential interest :
- Virtual Network, a module of Spatialite :
https://www.gaia-gis.it/spatialite-2.3.0/spatialite-network-2.3.0.html
- GraphServer : https://github.com/graphserver/graphserver/tree/master
- OpenTripPlanner :  http://opentripplanner.com/
> Mikhail,
> This is a very interesting idea.
> You might want to add specific support pgRouting which already supports
> building graphs, creating routing topology and solving various graph
> problem using postgis for geometry and tables for building and linking
> the topology.
> You might also want to look at:
> https://github.com/woodbri/osrm-tools
>    - a tool to move pgrouting data to Project-OSRM
> https://github.com/DennisOSRM/Project-OSRM
>    - a high performance routing engine
> A tool like you are describing that can load data and prepare a graph or
> move data between these projects would be extremely useful.
> I look forward to hearing more about your ideas.
> Thanks,
>    -Steve Woodbridge
> On 2/17/2014 5:13 AM, МОÑ
аОл Гусев wrote:
> > Hello everyone.
> > I am a last year student at Moscow Power Engineering Institute, Russia.
> > For GSoC 2014 I would like to work on networking capabilities in GDAL/OGR.
> > _
> > _
> > _Overall idea_
> > I would like to try to implement a universal network model. The
> > universality of the model would reflect not only in the ability to use
> > different GIS formats to store and transfer network data (which OGR is a
> > grate basis for), but also to be able to design and simulate different
> > types of network applications (engineering, natural, etc). I understand
> > that it is rather ambitious to consider all possible aspects of all
> > network types. But as a first step I would like to cover only the basic
> > aspects, that can be generalized and to provide a “platform” which can
> > be used by other developers to create their own extensions which are
> > specific to the concrete network type.
> > _Target scope for GSoC 2014_
> > Today none of OGR drivers supports network functionality. The idea is to
> > implement a new OGR driver, which will deal with networks built over the
> > spatial data. The spatial data together with the network data will be
> > stored in one of the OGR-supported formats, which would be specified
> > during the creation of the network.
> > Planned features of the new driver:
> > 1. Reading/writing data from/to the source, creating layers, editing
> > attributes, etc (as any new OGR driver must provide);
> > 2. The user would also be able to do the following, assuming that all
> > the special network data is the data of the current GIS-format:
> > - Read/Write the information about the whole network (network metadata);
> > - Edit special network objects parameters such as blocking state, or
> > direction of the flow;
> > - Import objects from the external sources (the driver adds missing
> > network parameters to them);
> > - Set/unset connections among network objects;
> > - Edit the sets of the network rules.
> > 3. Each object in the network will have a set of relations with other
> > objects, which are stored separately and form a network graph;
> > 4. The whole network will have a set of rules that describes the
> > connection possibilities of different object types in the network. The
> > network will also have a set of rules that describes the influence of
> > each type of object to the state of the whole network and to the other
> > types of objects. It can also be called as a behavior of the object in
> > the context of the network specialization (engineering purpose).
> > _Current status_
> > https://github.com/MikhanGusev/gnm
> > As a matter of fact I've been working on this for a while, and I've
> > already completed few things. Here is what I've accomplished already:
> > 1. Complete. The driver and most of the required virtual interfaces are
> > already implemented;
> > 2. Complete. All data from the external source is wrapped with the
> > network proxy and the user can edit it.
> > 3. Currently, I'm thinking about the way, how the network graph will be
> > stored.
> > Best regards,
> > Mikhail Gusev.
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
