[gdal-dev] GeoPackage fails after touching it with Spatialite-gui
Even Rouault even.rouault at mines-paris.org
Mon Feb 17 07:34:54 PST 2014
Selon Jukka Rahkonen <jukka.rahkonen at mmmtike.fi>:
> Even Rouault <even.rouault <at> mines-paris.org> writes:
> > Jukka,
> > I highly suspect that the ALTER TABLE must imply a rewriting of the file by
> > spatialite/spatialite-gui, and when doing so, it doesn't preserve the
> > "application id" (4 bytes in the header of sqlite file), that geopackage
> > specification mentions to be set to a particular value. Consequently the
> > geopackage driver later fails when checking the signature.
> I have not yet found a way to reproduce crash in a reliable way but while
> testing I found something else. Does the following mean that the GPKG file
> is not totally valid SQLite file or just that GDAL gets puzzled because
> there are separate implementations for SQLite/Spatialite and GPKG?
> Step 1: create plain SQLite and GPKG databases
> C:\data>ogr2ogr -f sqlite  test.sqlite temp.shp
> C:\data>ogr2ogr -f gpkg  test.gpkg temp.shp
> Step 2: try to rename a table
> C:\data>ogrinfo test.sqlite -dialect sqlite -sql "alter table temp rename to
> temp2"
> INFO: Open of `test.sqlite'
>       using driver `SQLite' successful.
> C:\data>ogrinfo test.gpkg -dialect sqlite -sql "alter table temp rename to
> temp2"
> INFO: Open of `test.gpkg'
>       using driver `GPKG' successful.
> ERROR 1: In ExecuteSQL(): sqlite3_prepare(alter table temp rename to temp2):
>   no such table: temp
Hum, well I can see that you are going to run into problems. The GPKG driver has
no ExecuteSQL() implementation that should directly handle your SQL requests
(what the SQLite driver would do). So it fallbacks to the generic ExecuteSQL()
implementation, which uses the sqlite VirtualOGR mechanism, which does not
support table renaming.
Ideally, the GPKG driver should be extended to implement ExecuteSQL() in a
similar way than the SQLite driver.
> I noticed that OGR dialect does not support renaming tables, it suggests to
> rename a column instead.
> -Jukka-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
